Old 03-24-2005, 05:49 PM   #1
Default Scored piston???
I have a new Rossi motor...i noticed that there is a deep scratch on the exhaust side of the piston [visible and you can feel it with your finger nail], it goes from top to bottom...there is no marks on the sleeve or anything that would make the mark..i suspect something entered the exhaust port and someone turn the motor over...
Here's my question...does it make a difference??? or do i need to replace it??? This motor has not been run or broken in...would it be worth running it anyways?????????
6Cuda6 is offline   Reply With Quote
Old 03-24-2005, 07:42 PM   #2
teammpp's Avatar
Probably will need to replace it. That score will trap oil which will start to gel. When that happens it starts creating other problems and can actually because so hard that it cuts into the sleeve.
teammpp is offline   Reply With Quote
I need a piston for an evo .21 nitroburner65 R/C Items: Wanted to Buy 2 07-06-2008 10:06 AM
Light Oil & Small Piston Hole vs. Heavy Oil & Large Piston Hole Rich Panganiban Nitro On-Road 2 01-26-2006 03:24 AM
I scored!!! toytech Monster Trucks 21 01-05-2005 09:49 PM
where to get a piston set for a ek4 2mcgrath Monster Trucks 0 03-17-2004 08:15 PM
piston tdragon Nitro On-Road 1 04-29-2003 04:17 PM
SEO by vBSEO 3.5.0
