Ofna 095 Pipe
Ofna 095 Pipe
So did some digging around and couldn't find much info on this pipe. How does Ofna 095 compare to the Ofna 086? From what I can gather they're both 2 chamber power pipes. The 095 has a smooth flow header with a 9.5mm stinger, where the 086 has a double bend header with a smaller stinger.
Comparison of these 2 pipes?
The 095 is better suited for larger displacement engines. (the larger stinger)
But the engine will use more fuel.
The double bend header seems to be a peakier rpm band. The 180 degree header seems to be smoother more linear.
