Old 07-09-2012, 01:14 PM   #16
lil-bump's Avatar
Trader Rating: 82 (100%+)
Originally Posted by wingracer View Post
Al most of the red AROs are is ATF. So if you like it, go get a bottle of ATF from the auto parts store.
Marvel Mystery Oil is just ATF with oil of wintergreen added.
ATF is a good ARO. The only problem is that they say it can damage the silicone ramps in many cranks these days. I have never seen it, I suspect you would have to soak it in ATF for months to have a problem. Still, just to be safe I switched to a synthetic oil. Mobil One is doing just fine for me.
I had a NIB Nova 3SCT that I had sitting for about 1 year. I added an ample amount of MMO every 2 months to keep the moisture out. Once I was ready to use the engine, I notice the silcone ramp had swollen. I still use MMO for short term use but for long term storage I would use some other type of lubricant. Or do not saturate the engine crank
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
After run oil: who uses it? jeff_ellis_9 Nitro Off-Road 46 05-25-2010 09:01 PM
after run oil redza Nitro Off-Road 20 02-09-2009 02:55 AM
After run oil piorc Nitro On-Road 16 06-15-2005 06:15 AM
marvel mystery oil zombi Nitro On-Road 10 04-28-2003 10:19 AM
SEO by vBSEO 3.5.0
