Old 02-11-2005, 07:27 AM   #1
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via ICQ to squarehead Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Default Can someone explain...
...exactly what an SG crank is, how it differs from a standard crank, and what the benefits or uses would be? What wouold require the use of an SG crank?
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 02-11-2005, 09:50 AM   #2
uaerc's Avatar
As far as i know SG crank is a longer one and the abbreviation 'SG' just represents the size of the crank.. An SG type crank is used in almost all touring cars... as its a bit longer.....
The other threaded type is usually used in trucks etc...
I dont think it has anything to do with performace... correct me if i am wrong ppl......
uaerc is offline   Reply With Quote
Old 02-11-2005, 02:33 PM   #3
soc123_au's Avatar
The SG crank is less likely to be unstable at higher RPM, The reason is the clutch & bell are attatched to the crank directly. On a threaded crank the clutch is attatched to a pilot shaft (long flywheel nut) being 2 peices give more chance of vibration etc.
Serpent Radio Control Models
Auswide Hobbies
JPM Racing
soc123_au is offline   Reply With Quote
Old 02-11-2005, 05:45 PM   #4
jag's Avatar
An SG shaft allows the use of a 2-speed clutch without having to use a pilot shaft/nut which, as previously stated, is not the best for several reasons. I do not believe the SG shaft makes more power but I do think most companies use an SG shaft in their best engines.
jag is offline   Reply With Quote
Can somebody please explain this to me? sho .21 R/C Racers 4 Christ 222 11-18-2011 02:06 PM
PLZ explain me this! hrnts69 Radio and Electronics 0 02-17-2008 09:45 AM
tires please explain.. Rock'sTC3 Electric On-Road 4 08-22-2007 07:06 PM
explain gearing rcjayy Nitro On-Road 16 09-13-2006 06:07 PM
Is it possible to even explain to someone why you need more than one car? LosiFromHell986 Chat Lounge 32 05-17-2004 04:15 PM
SEO by vBSEO 3.5.0
