RB Concept V12 Circuit 3 Ports 'Rody'
RB Concept V12 Circuit 3 Ports 'Rody' vs Collari?
I have been looking at these motors based on my earlier question about a serious powerplant for my 710. RB Concept V12 Circuit 3 Ports Rody tuned. Are they up there with Novarossi ETC ....
I have decided to either go for this RB or the Collari motor 'L. Collari WRXLC12PRO3' 3-Port, ROAR Legal, .12 AAC, Turbo Plug, SG Crank, Low CG Design
Any comments appreciated
Thanks again
Scott
Thanks again
Scott
I have an Rody V12 3 port. It runs very good and is very fast.
It seems that the Collari is quite a bit cheaper as I can get it in the states for $295 while the RB Rody seems to be around £300 as I can only get it in the UK.
Originally posted by acutts
Is it correct to assume that the Rody JB is a Novarossi based motor and the Collari based on Picco?
The RB is based on the Novarossi but the Collari is based on the Sirio I believe.
The Sirio, Mega, Picco all seem to have very similar crankcase? It has to do with the engine monoblock for the 710 ... there are 2 different blocks depending on Picco/Mega based engines and the other is for Novarossi based motors ... I have the Mega/Picco one so need to get a motor that will fit :-(
Not sure really so going to ask Serpent to find out before I buy ...! I guess I could use the original blocks ..... but the monoblock is way cool ... and nice anodised orangy ....
Shre your secrets
Can anyone please tell me the needle settings for a 1700-000410. I bought one second hand and have just bought a new sleeve and piston head. I have gone through the break-in process and things sweemed to be going well.
Except today when I was racing the engine kept cutting out. It would cut out when applying throttle. I didn't finish one race.
When I bought the engine I foolishly turned the needle that is on the slide carb. I have no idea what the setting should be.
Any help for all three (running) settings would be appreciated.
Thanks in advance.
Thanks in advance.
factory settings is about 5.25 turns from closed on the high speed needle and about 2.5 turns from closed on the low speed needle.
and the midrange screw should be flush with the carby
