sirio xxxv .12 motor problem
Hi all i have done only 2.5 litres in my sirio and noticed the shaft moves very slightly and the motor doesnt run any answer to why its doing this?
Any advice would be helpful:) |
Hi mate,
I'm no nitro expert but I suspect the experts who do lurk the boards are going to want a little more info to help identify the problem. Does the motor have compression? Glow plug is ok? Does it start and then stall or just not start at all? I wont have the answers for you but a little bit more info and I'm sure someone on here will point you in the right direction. Simon |
It has compression and the glow plug is fine, when i turn the flywheel it feels rough the car turns over but doesnt idle it just stalls
Originally Posted by wozzie
(Post 10418283)
(Post 10418144)
Any advice would be helpful:) opened her up and checked inside? I would. |
i just did it seems like the bearing is shot, the shaft looks fine
(Post 10418455)
Ready with the oven gloves? |
Do maintenance. readjust flywheel endplay. Thrust brg etc. Typical nitro maintenance.
