OS 12 TzR
#1021
Is the OS speed TZ available in the market yet?
#1022
Originally Posted by mrgsr
andy how about a drag race with my mod tz
Cheers
#1023
Originally Posted by cars.cars.cars
hey...I was just wondering what a good pipe is for the OS TZ 5 port?
Thanks in advance.
Thanks in advance.
Cheers
#1024
is anyone else having issues with the fins, i´ve had two tzs and they both had the same problem, all the tz racers in my club have the same problem, my engine has just two gallons and it lost already two fins!
#1026
Originally Posted by gijoe64
Stop crashing.
#1028
both of my 5 ports did it very early in there life. but it doesnt seem to affect performance.i havent seen it on the 3 ports though
#1029
regarding the os tz speed, its a limited edition, price is 34300 yen, pro futaba at japan sold out that engine!
#1030
anyone know if the pullstart off the 18tz can be made to fit the 12 tz?
#1031
WRONG ANSWER GIJOE! FIRST TIME HAVING LOOSE FINS ON MY 7TH ENGINE SO I GUESS YOUR ANSWER IS OUT OF QUESTION!
#1032
they give way around the centre of the head and drop down.i've seen a few 5 ports do it. you dont need to crash to do it. you can actually feell them starting to get loose
#1033
Maybe its metal fatigue?....i had this happen to an old RB V12 i had.....the fins eventually just dropped off over time. Or maybe an earlier crash causes hairline cracks that eventually open up?
Cheers
Cheers
#1034
compared to other engines like the tr for instance, the fins are thinner, that could be the reason.
on a crash the fins brake inmediately, not so here, had to use poxibonder (kind of metallic pot) to avoid one fin to continue to get loose by vibration!
#1035
Hi
I have the 5 port TZ .. do I have to increase the head clearance ?
If so ,, what mm should i put ?
Thnx ..
Thnx ..
