fuel leaking from max fantini 12 xxl3
i think iv got a leak in my crankcase theres fuel leaking around the area where its screwed to the engine mounts on opposite side to the slide carb......i can see a mark which clearly isnt on the other side of the engine which im guessing is the crack......does anyone know where i can get a new crankcase from or if i could use a novarossi 1 i uploaded pics of both sides of the crankcase
as u can see the side with novarossi engraved is fine but the other side with made in italy engraved is different
just to point out its definetly not the fuel lines or anything else its only leaking raw fuel on 1 side of the engine mounts
Solution 2. Try to find a finished used engine from ebay etc.. Take the crankcase from that...
Solution 3. Try to seal the current crank case. (glue, sealant, welding....)
Solution 4. Buy a new crank case from novarossi. (I wouldn't do that, too expensive for a used engine)
-X-
