MEGA (by Picco) thread
#991
Originally Posted by Qlone
The rod without the bushing at the top is the improved version, yes. It should last a lot longer than the original version.
Where did your bushing go? Did it get loose in the engine and possibly ruin the engine? I have photos of a MAX312 engine where one of the balls of the rear bearing failed and flushed into the combustion chamber:
Not a pretty sight, and it shows why you want to check your engine internals every now and then...
The bushing turned into bronze dust which ended up everywhere in the engine. I think it's ruined but I may be able to salvage a few spare parts.
#992
Originally Posted by Paolo M
Hi Mrgsr,
Main needle flush
Low speed needle 2 mm
This is a starter point on the rich side
Paolo
Main needle flush
Paolo
#996
Originally Posted by mrgsr
hey guys im trying to find a manual for the dsII zx .21
does anyone have this and can send to me ?
i cant find it on the mytsn site
thank you
thank you
Ask him, because the manual should be in the box....
But, the manual doesn't tell you things we don't already know......
#998
Yes, it's 2mm out of the ball link, but this is on the rich side I think, mine is about 1mm out of the ball link.....
But, just try and re-adjust the needles till the engine runs correct, slightly rich on the bottom.....
Also here in Holland on some Dutch forums, people keep asking for base settings of an engine, but an engine needs to be adjusted to the local environment (fuel type, temperature, humidity, level) so learning to adjust it yourself, is the best you can do.....
#1000
DS11 reliability
Originally Posted by quietstorm76
Does anyone have a update on the durability of the .21 DSII?
Specifically rod failure.
When you compare the speed and acceleration of this engine to all the modified 35+21 engines at our track I think you have to admit the DS11 is not giving away anything in the area of performance and it is doing this at about 1/2 the price of these other engines.
#1001
Originally Posted by Winner's Circle
Quietstorm you saw mine run. It is a missle and also an unbelievable value when you consider what it cost and my engine is totally stock. I'll tear it down if you want to look it over.
#1002
DS11 powerpack
I love that engine and it will be my next one for sure. I was just curious if anyone has had any rod problems with it. I know yours is fast as hell, I brag on it all the time. I saw you running with you-know-who Sunday and you all were dead even. Btw are you running the power pack?
I love this engine! I have them in stock!
#1004
The word goes, that the DSII, with the newest Novarossi pipe, (EFRA 2054?) has 1 huge benifit, the flame out problems are solved........
MS had some problems with his engine at the EC or GP in Sweden a few weeks ago, and after switching the exhaust by the 2054, the engine was running perfectly.....
We will probably see a new Mega pipe coming during the wintermonths, with the same measurements (roughly) as the Novarossi...
