MEGA (by Picco) thread
#571
Originally Posted by Dynamite
This is after about 6 litres of fuel and roughly 7~8 hours of racing, not including run in time - which was done per manual.
fuel used throughout was 16% with 12% oil (50/50 castor/synth).
#572
Originally Posted by gonzoY5
Was there any damage anywhere else in the engine?
pitty as motor still had abit of compression, not that it ever had the 'nip' at the top of a nova motor even when brand new out of the box.
now i need a new p/l & rod set, cranks fine bearings are all fine and shrapnell now removed.
#573
Murnan Mega/Picco 12
Just some shots of my Murnan Mega/Picco 12. I'm still breaking it in. I've got 10 tanks though it and it is already screaming. It idles very smooth and it seems to be strong throughout the powerband. I highly recommend a Murnan to all seeking exceptional performance. Enjoy
#574
Originally Posted by Tabushi
Hi, i have a friend with a little problem on his ZX12 ... he finished the break inn period on a TM G4 EVO car ...
The thing is that the engine throw a lot of smoke with good temps n the track, a lot of power BUT he is burning glow plugs as hell !! ... he went over 3 plugs on 5 hours of practice time ... and dont know what to do ... he have the stock shim setup so he asked me to post here the problem and see your opinions about a solution ...
thanks,
thanks,
check engine!
#575
Plugz..
Anyone know if OS plugs work well with the ZX12?...Where I live it's kinda difficult to get hold of the MEGA plugs.
#576
#577
zx21 exhaust port
Has anyone got any info on the exhaust port heights on these. I have seen heights of about 4.5 - 5.2 mm ?? Not modded.
#579
Originally Posted by Riketsu
How do I know if my conrod is the new version or the old one?
so if it's older you have the previous version......
#581
Your LHS?
#582
Managed to finally run my MEGA after a thorough check on the carbs and internals. During the break in period i found the spring on the idle screw to be loose and tightens itself when you rev it. Easy fix by pulling the tension on the small spring to make it stiffer and a drop of thread lock on the needle to leave some residue so it's not so loose. What i found surprising was the difference in tuning compared to a NovaRossi based engine which we're used to running here in Asia. I had to richen the low end needle to a point where the screw was jutting out almost 2mm. This beast has got loads of torque. I run a 710 and had to screw the Centax tension to 2mm(Centax2 spring) from the normal 1mm i'm used to. Boy, what a difference it made. The car came alive almost immedietly.
Most of you must've had the o ring problems with the low end needle. I had a local modder remove them and sand the gap for the o ring a little bigger and replaced it with NovaRossi o-rings. No more issues there.
#584
Typo- Should be zx12
