Old 12-08-2004, 06:47 PM   #1
Default ENGINE Break in
Who can tell me how to judge whether or not an engine is break-in OK?
what is the judgement standard?
adsl is offline   Reply With Quote
Old 12-09-2004, 09:41 AM   #2
Do you mean method or whether it's broken in?
There are many argued ways of doing a break-in. The most common method involves:
1. Choose your nitro percentage for break-in for the proper hysteresis process, and DO NOT change nitro percentage after break-in (or you will need to re-run a break-in)
2. Do not run idle tanks
3. Running the engine at as rich a condition as possible and at no more than 1/4-1/2 throttle for at LEAST 8 tanks
4. Break it in under LOAD, that is, put it on the ground and drive it around at the above throttles during the break-in
5. Allow FULL COOLING between tanks to aquire a proper heat cycling
There are many actual methods.
rocknbil is offline   Reply With Quote
Old 12-09-2004, 06:01 PM   #3
mckrooz's Avatar
Send a message via AIM to mckrooz
I've switched from 20-30% many times and never have to break in. I think you mean re-tune.
Kyosho RRR Evo2
mckrooz is offline   Reply With Quote
Old 12-13-2004, 09:54 AM   #4
No, I mean re-break-in.
The process is called hysteresis.
How not to break in an engine ! Maximo Nitro Off-Road 4 08-05-2008 09:34 PM
engine break in 37 RACING Nitro Off-Road 10 03-15-2008 02:25 PM
Engine break-in ? acsubie Electric Off-Road 3 05-11-2007 07:42 PM
How do you break in an engine? joe of loath Rookie Zone 12 03-26-2007 03:08 AM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 10:49 PM
SEO by vBSEO 3.5.0
