M Rossi REDS Racing M7T
#76
Piston/sleeve has 7+3 ports on the M7T, the Torque 7+2
M7T Sleeve has tear drops
Crankshaft lightened, red putty inserted and its balanced
Combustion chamber lightened on the M7T
High quality ceramic rear bearing, not standard on the Picco´s
Over all weight is lighter on the M7T 310gr, the Torque 335gr
So it's a Picco on steroids... So it's actually closer and better to the Picco EDO modified engines....
If you ask me :-)
#77
brand new 2012 engine
Hello,
I have one brand new engine for sale,first come first serve!
http://www.rctech.net/forum/r-c-item...1-new-box.html
#78
The M7T from REDS is based on a Picco engine in the sense that the only thing they have in common is the Bore/Stroke ratio. The rest is different and better on the REDS M7T as fare as I can see.
If you ask me :-)
If you ask me :-)
Thanks for the input, I will be getting two of them today.
I have an EDO which I still need to run and M21's. Very keen to see how these perform.
And I am assuming the fuel mileage is good on these engines when compared to Nova based?
Thanks for the input, appreciate it.
Regards
Warren
#79
Wow, these things are really been tuned when compared to the stock mills.
Regards
Warren
Regards
Warren
#80
That is re assuring, with gooping being allowed mileage is going to be a bigger issue than ever.
#81
New M3 WC and M7 WC
Hi,
New REDS engines are available
http://stores.ebay.com/Kangaroo-Comp...=p4634.c0.m322
Thanks,
Niko
Thanks,
Niko
#82
Does anyone have some feedback on the XL Strokes preformance. Started breaking in my M7T on Sunday with 16% and the thing is a bullet.
Stronger mid range perhaps?
#83
They are really fantastic!
#84
Thanks for the feedback, I have some coming soon.
I am very happy with these engines, superb machines!!
#85
reds m7t engine bearing
hye guys,
im from malaysia.
i have this engine, and the bearing is making hell of a sound.
any idea which other model bearing that suits for this model as im having difficulties in finding the reds engine bearing...
is the os speed spec engine bearing can be used?
im from malaysia.
#86
Bearing size is front 7x19x6 and rear 14x25.4x6 ... so bearings for an OS Speed will fít, and so will Sonic, Picco Torque and Novarossi Kangaroo ... good luck; Best wishes; Jens
#87
#88
I can help you, we got it on stock and ships world wide.
You can PM me and I'll make you a quote including shipping.
You can always find REDS parts here:
Thanks,
Niko
#89
REDS Spring RUN-IN
By the way here's a link to a few videos of the first spring run-in of the A REDS R5 Classic and a REDS M7 WC :-)..
http://www.youtube.com/watch?v=ikD-2CfM6e0
Take a look!
Niko
Take a look!
Niko
#90
M7 WC XL
Hi guys, any one having difficulties to remove the conrod form the crankpin? Thru the usual way, sleeve removed, conrod still unable to remove at TDC, any advise is appreciated. Thanks.
