Old 10-08-2004, 08:55 AM   #1
Default When to change crankshaft
I have got a Novarossi race 21,
when do I need to change the conrod, and when do I need to change the crankshaft.
Eric2004 is offline   Reply With Quote
Old 10-08-2004, 09:40 AM   #2
crankshafts are probably the most durable part of the engine....
The parts you will most likely need to replace are:
-Piston & Liner
-Connecting rod (integrated bushings)
-Front & Rear bearings
You will know when the piston and liner need replacing, the compression will drop, the engine won't have the "edge" it once had, and idling may be unreliable.
I always replace the conrod at the same time as the piston and Liner, as the bushings do wear and get sloppy.
The crankshaft and wrist pin/gudgeon pin are made from extremely hard steel and should last almost indefinately if properly maintained.
The bearings can last a few rebuilds, if they are kept clean and no dirt has been able to enter...
You can't really put a label on an engine stating the life, it will vary with fuel used, application, maintenence, etc.
jamiekulhanek is offline   Reply With Quote
WTB SG Crankshaft for OS RG robertsmustang R/C Items: Wanted to Buy 0 02-19-2008 05:11 AM
HPI F4.1 Crankshaft marvs777 R/C Items: Wanted to Buy 0 12-22-2007 01:29 AM
JP FX3 CRANKSHAFT rchopeless Australia Wanted to Buy 0 01-01-2007 02:47 PM
crankshaft haowee Singapore R/C Racers 0 09-26-2005 07:16 AM
crankshaft TRF_TG10R Nitro On-Road 1 06-14-2003 09:51 PM
SEO by vBSEO 3.5.0
