Main Engine Bearing (.12)
Does anyone know what diameter the balls of the main inner bearing of a 11.5 mm diameter crankshaft version of a .12 engine? How many balls are there?
I found out that for the 11mm crankshaft versions, the diameter of the balls are of 1/8" and you need 8 of them.
Thanks.
Thanks.
Thanks for the reply Dennis. I was hoping I did not have to open up a new bearing just to find out.
I think you know the main reason why I'm asking this.
I know the balls are smaller than 1/8" because 1/8" are used on the 11 mm crankshaft versions. So it could be 3/32" or 5/64" if they are indeed standard size balls...
