O.S. SPEED Tuned 21XZ-R
#76
so has anyone got anymore feed back on the Speed motor??? how was the run in? easy or hard? any problems anyone has come across?
#77
Yeah, i'd like to know what others think about this engine as well since it was like sold out everywhere after being release within 2 days.
Although i've seen this engine on our tracks here, what i gather is that the engine is respectable in it's price range. Definitely not super ballistic ridiculous fast like the other 1k engines...
However, i believe i found another engine that compares with affordability to this engine which is the Picco Torque Edo Modified. Anyone compared these 2 engines yet?
#81
But for only $390, add a ceramic bearing and maybe a touch up here and there, and it will be.... Hara and Shimo qualified 2nd and 4th at the WC with it, so he potential is obviously here.
Cost of spare parts was also a deciding factor.
#85
Unstable idle
Anyone experienced the unstable idle, even pinch test the LSN and idle are good, but the actual idle cant stand for few second.
I'm using RP7 plug, shd 6 better to stable to idle?
#86
Hi, have the same problem, I'm having to replace the rod and main bearing as mine is due for it, how old is the engine ?, there were issues with the engines when they first came out, check back on this post.
Andy
Andy
#88
will be running in the SPEED in the next few weeks, so i will keep you posted on that how that goes, i also will be trying the odonnell 99T plug.
#89
Its new, just change the con rod. This symptom was found when it's new.
#90
Beebone, i noticed the same thing with my Ver2 XZR, unstable idle whilst on the track whist running in, the only thing that i done was reset my idle stop screw with the Venturi out and reset my throttle trim on the controller,i did this because the linkage was not returning to the close position fully. all it needs is that little bit to be open and then it is unstable, and then towards the end of the day the car was coming into pit lane on medium to high rpm and then drop down to a nice idle.
