Like Tree3Likes
Old 06-11-2011, 08:23 AM   #31
Trader Rating: 47 (100%+)
Originally Posted by choisan View Post
my friend helped me to buy it from HK, it is very nice price. but i didn't buy with a pipe. i will use my 2018 of max instead. the os 2080 pipe is too expensive to have.
I hope you and everyone else on this thread can leave some
feedback on what tuned pipes they have tried running on this
engine.
If I ever get one for myself, I am going to see how well a Werks 2058
pipe does on it.
rageworks is offline   Reply With Quote
Old 06-11-2011, 09:50 AM   #32
choisan's Avatar
will definitely do
choisan is offline   Reply With Quote
Old 06-11-2011, 05:33 PM   #33
Originally Posted by v.v. View Post
Need to do some modifies in order to install on the RX8, hope xray will release a option engine mount later
Just bore out the holes on engine a bit, I did mine yesterday, just measure the distance between 2 holes around 37.8mm.
beebone is offline   Reply With Quote
Old 06-13-2011, 01:13 AM   #34
bigredspeed's Avatar
I used a 3.5mm drill bit on my 1st version OS 21XZ-R and it fits perfect now
Tornado Racing Fuel and Product
Sanwa
XRAY RX8,ZAC OS SPEED XZR
XRAY X12,Muchmoore Fleta
Hudy, HEI international
bigredspeed is offline   Reply With Quote
Old 06-13-2011, 02:31 AM   #35
X4
X4's Avatar
engine.
pipe does on it.
3 of us ran the engine last Friday. I was using a Nova 2015 with a medium manifold, 1 had the OS T-2080 pipe set and the other had an old ninja pipe.
The guy running the OS T2080 pipe had the best performance of the 3, but not much of a difference to the Nova 2015 (top speed and torque). The guy running ninja pipe was weakest on the straights, took more effort for the engine to spool up.
In terms of fuel consumption, all 3 had almost identical run times.
My engine was running around 90-95 degrees. I'll try leaning the engine slightly the next time i run before i give the final result on this engine, but i have to admit, so far, for the price of this engine - ITS TOTALLY WORTH IT!
X4 is offline   Reply With Quote
Old 06-13-2011, 01:27 PM   #36
GREGORY!'s Avatar
how much is that price?
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 06-13-2011, 04:45 PM   #37
firecat's Avatar
cant find the speed version anywhere even rcchamp as posted earlier unless wrong web address
team scream racing/ts racing/kyosho mp9 tki3/ xray xb2 xb4/Wolcott hobbies and airsoft/rc madness
firecat is offline   Reply With Quote
Old 06-14-2011, 03:27 AM   #38
ugglasdav's Avatar
RC model at the moment have both versions of the new engine http://www.rcmodel.com.hk/
>Shepherd Velox V8/Team associated TC5R
>>IDM 2011/ Speed passion/Much More
>>>Sanwa m11x
ugglasdav is offline   Reply With Quote
Old 06-14-2011, 06:42 AM   #39
Yes, I tried couple of tune, I found the engine extremely cold, around 85-90 something degrees, the hottest tune is 103 degree with a bit lean bog on low end.
Old 06-14-2011, 12:06 PM   #40
Whatīs the difference between the Version II and the first XZ-R .
Is the tuned Version much more faster than the Version II .
Is the difference of speed worth to pay more .
Who knows if the Version II got the same power curve as the first XZ-R .
The first XZ-R was a beast . Is the Version II smoother than the XZ-R
Who can tell me something about this facts ?
Thanx
Blessed Speed is offline   Reply With Quote
Old 06-14-2011, 03:26 PM   #41
I am also interested about this, too.
I can only find the OS .21 XZ-R:
http://www.rc-toro.com/product_info....5bd3057d6db239
Who else sells the OS speed version?
silverM3 is offline   Reply With Quote
Old 06-14-2011, 08:51 PM   #42
Thanx
This is my first OS, dunno about the OS XZ-R ver2.
The speed is acceptable when I compare with Flash21 PT, but dunno about the durability yet. At least my RX8 can swing the tail in tight corner when using the OS
Old 06-15-2011, 05:45 AM   #43
Hi guys I have ver 1 and now I have ver 2 21XZR. I missed out on getting the speed XZR but when I pulled the motor down to have look I noticed it exact same internals as the ver . The only change is the heat sink and I noticed the crank case has different part number. I don't know why because they look identical inside and out. I am little bit upset by this because I could of just replaced the internal parts on the ver 1 And saved money instead of buying a whole new engine. Looking forward to getting the speed version when it is available again. I recommend changing the rear metal bearing to the speed ceramic bearing. engine spools up Smoother
Sanwa
Old 06-15-2011, 07:03 AM   #44
Speed version doesn't come with ceramic
Old 06-15-2011, 10:46 AM   #45
A friend of me got the Vers.1 and this engine is amazing . Very strong couple and good topspeed . comparable with 9port engines .
But for me, ports and lights are not so important .
I only want to know if the tuned one got other timings as the Vers.2 .
Because if its only tuned with flowcorrectors on the lights I mean the Vers.2 can be enough .
Grinding is not a science And ceramicbearings arnīt so hard to find .
I want to try this Vers.2.
