Like Tree3Likes
Old 11-20-2014, 07:43 AM   #331
Originally Posted by ralphierace13 View Post
Don't know that fuel but 3% oil is not alot at all. We have not had any trouble with ours we don't even change the first rod till 5 gallons.
Agreed. Never had a problem with the speeds. Change one main bearing a year ago...and still on the same rod...idles and runs hard.
V-one-RR Evo,V-one-RRR (WC hopped-up),2007 Evolva,
Spada 09,MR-02,MR-03
Inferno GT2. Serpent Cobra GT
KF01 - F1, Serpent Viper 977WC, Serpent Natrix 748
1FastVW is offline   Reply With Quote
Old 01-14-2015, 06:52 PM   #332
swerv's Avatar
I too was looking in to OS engines...... I also her same thing about the issues with the bearings and the rods breaking..... .21XZ R VII & .21XZ R SPEED ..... I just want to know are those motors beastly ? Do they sit on the top of the food chain ? (I did not read the whole thread I just read this page)....
insane in the membrane for nitro methane ......
swerv is offline   Reply With Quote
Old 02-26-2015, 04:21 PM   #333
1/8 IC Fan's Avatar
Trader Rating: 47 (100%+)
Originally Posted by Tabushi View Post
Hello crew ...
one question ... im starting on 1/8 onroad
I need some feedback on OS .21 XZ-R V2 (OSMG2042) ... its on my budget and it seems that, not being the last and top model right now, would be a good contender on track. My other alternative if i dont get this OS model, will be Novarossi ISON 7 ports Onroad .21
Thanks a lot for your feedback,
Just to piggy back on this, has anyone compared the V-II and the R2101 side by side? I know a lot has to do with clutch and carb setup, but looking to see if the V-II is less explosive in power delivery and would be a candidate for a classic 1:8 Pan car?
-if you can't get ahold of me I am probably working, and that's out in the ocean. So please have patience when trying to correspond. - Thank you.
--->When in doubt try the Search Tab, it can and actually will lead to an Answer!
1/8 IC Fan is offline   Reply With Quote
Old 03-01-2015, 02:27 AM   #334
JamesHealey's Avatar
You want the RB Classico or Speed for pan car racing, they're the most progressive power delivery out of any on road engines you can buy, very good for pan cars.
Sorry not an OS, but the aforementioned engines are designed for this class and perform very well.
Serpent 977 Evo | Novarossi Engines | Racing Experience Fuel | Xpert-RC Servos | Xtreme Tyres | Bitty Design Body Shells |
http://answer-rc.com/en/ - Answer RC supported driver.
JamesHealey is offline   Reply With Quote
Old 03-01-2015, 06:57 AM   #335
1/8 IC Fan's Avatar
Thanks, but the Classico nor the Speed are available here in the US. Trying to see if the OS would have fit the bill.
Old 03-01-2015, 07:22 AM   #336
GMartinez's Avatar
Trader Rating: 85 (100%+)
I purchased the R2101 superior hobbies
There also available thru tower hobbies
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 06-16-2015, 08:55 PM   #337
dameetz's Avatar
Just want to ask if the 21 XZR VII (not the Speed) comes with DLC coated crankshaft. OS says its DLC link but when I browse the part no it is not. Which is correct?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 06-17-2015, 12:39 PM   #338
The one with the blue head? No DLC coating.
Old 06-17-2015, 02:04 PM   #339
dameetz's Avatar
Ok thanks for the info thats what I thought too....I wonder why OS mentioned it is DLC coated though.
Old 07-23-2015, 12:26 PM   #340
vernon7026's Avatar
Send a message via MSN to vernon7026
Hello all
What would be a decent pipe for this engine ?
Regards
vernon7026 is offline   Reply With Quote
Old 07-29-2015, 02:18 PM   #341
ralphierace13's Avatar
Originally Posted by vernon7026 View Post
Hello all
Regards
fastest pipe for this motor is the 2015 nova hands down. a little bit less run time but most power. I use the nova short header for the 2015...
RALPH FORTUNATO
MUGEN SEIKI MRX6 TEAM DRIVER
Futaba 4PK-S-R, Novarossi Team Driver, CONTACT TIRES
Byron Fuel, Veytrex Desgin Labs
2014 R.O.A.R. REGION 1 CHAMPION!!
ralphierace13 is offline   Reply With Quote
Old 07-31-2015, 09:05 AM   #342
dameetz's Avatar
Is the p/s/c set of OS Speed R2101 compatible in a XZR V2 motor? I know they share the same conrod.
Old 07-31-2015, 02:14 PM   #343
No
Old 08-01-2015, 02:40 AM   #344
dameetz's Avatar
No
Ok thanks, anyhow today I fitted my XZR v2 with R21 p/s/c it fit really well, looking at the exhaust ports there are aligned perfectly. I did not try to start it though. So just wondering what makes it not compatible in an XZR v2 crankcase?
Old 08-01-2015, 03:02 AM   #345
For starters it might look like the ports are matched up but they are not. Also 2101 was made as a long stroke so u need the crank from the 2101 or the piston does not travel far enuff up the sleeve then all the timings are off plus the boar of the sleeve on 2101 is much smaller so without the crank u have no power...
