O.S. SPEED Tuned 21XZ-R
#317
Hi, im looking for PSR set for this engine but no luck so far. Just wondering if the PSR set for the R2101 is compatible with this engine. Thanks.
#318
Brooklyn hobbies has one set left and absolute hobbies has them but u have to call not listed on their Web site
#320
Thnks for the replies guys. Will try the options.
#321
Head Clerance
What should the head clearance be on a XZ-R speed? I got a new piston and liner but I bought the version 2 which is different according to a previous post. I want to make sure I get the head gap right so if anyone knows the required clearance (using solder) that would be very helpful.
Thanks!
Thanks!
#322
Hello crew ...
one question ... im starting on 1/8 onroad
I need some feedback on OS .21 XZ-R V2 (OSMG2042) ... its on my budget and it seems that, not being the last and top model right now, would be a good contender on track. My other alternative if i dont get this OS model, will be Novarossi ISON 7 ports Onroad .21
Thanks a lot for your feedback,
#323
Hello crew ...
#324
#325
#327
yes,it is OS speed. they broke the rod often compare to other brand,even with engine's temp below 100 c. here is high humidity and air temp between 32-36c,any idea?
#328
here in ny in the summer we have same conditions high heat and high humidity and we don't have any problems. after how many gallons do u change the rod? we change it every 5 gallons. also what fuel do u run? most guys here run byrons, I use kosmic.
#329
i got a friend just replace a new rod but broke not even 2 tank run,he use rapicon with 3% castol oil added
#330
