Like Tree3Likes
Old 09-30-2013, 07:25 AM   #301
Stuff Of Legend's Avatar
Cool :) humm! Cant Wait
http://www.os-engines.co.jp/2013/r2101/
RC STABLE.....
SERPENT VIPER 977e Evo2
TRAXXAS XO-1 / YOKOMO BD7 2016
HOBBYWING motor/esc - PROTOFORM/BITTYDESIGNS bodies
SAVOX servo's - SPEKTRUM tx/rx - XCEED tire's
Stuff Of Legend is offline   Reply With Quote
Old 09-30-2013, 07:35 AM   #302
All i see as diff is the head design & the current trend of longer stroke... and somethings going on with the rear bearing
Old 09-30-2013, 08:40 AM   #303
Arahawak's Avatar
Trader Rating: 32 (100%+)
Crankshaft is DLC coated.. not many in the market.
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 09-30-2013, 09:28 AM   #304
the previous model not DLC coated?
kyosho malaysia is offline   Reply With Quote
Old 10-08-2013, 03:51 PM   #305
DDG
Is this engine available already?
DDG is offline   Reply With Quote
Old 10-08-2013, 06:16 PM   #306
Yes
No
Old 10-13-2013, 01:41 AM   #307
Flygio's Avatar
What's up with the rear bearing?
Serpent 977 - Fidelio Telemetry Software
Flygio is offline   Reply With Quote
Old 10-13-2013, 09:19 AM   #308
Looks bigger from the outside design of the block.
Old 10-15-2013, 07:31 AM   #309
ralphierace13's Avatar
does anyone know what pipe header combo all these guys from the worlds were running on the os, from what I see its the 2080sc pipe but the header I cant tell cause there using springs to connect the header to the pipe?
RALPH FORTUNATO
MUGEN SEIKI MRX6 TEAM DRIVER
Futaba 4PK-S-R, Novarossi Team Driver, CONTACT TIRES
Byron Fuel, Veytrex Desgin Labs
2014 R.O.A.R. REGION 1 CHAMPION!!
ralphierace13 is offline   Reply With Quote
Old 10-19-2013, 05:49 AM   #310
Originally Posted by Valerio View Post
I'm breakin my OS Speed, takes about 3 liters. Running at a temperature of 90 , the engine begins to run fairly and reaches high rpm but at low rpm the engine has no power. Is this normal? The LSN is 4 and 1/2 turn out. could tighten more? Is this correct? Can i turn in it?
How come you used 3 liters to break in your engine?
Doesn't it should be 1-2liters?
Capricorn LAB C801/OS ENGINES/FUTABA/FUTABA
victor1997621 is offline   Reply With Quote
Old 10-19-2013, 05:51 AM   #311
What is the difference between OS T-2080 and T-2080-SC?
Old 10-19-2013, 08:09 AM   #312
Arahawak's Avatar
The SC pipe and manifold is held together by conventional method, the 3 spring. The one without SC is holding the pipe and manifold together by a 2 piece ring.
Pro Shop Futaba and RC champ already has them.
Old 11-03-2013, 09:38 PM   #313
Pics of the R2101, received today direct from Japan.
I have had a change of plans since ordering this engine, so it is listed in the for sale section if anyone is interested.
O.S. SPEED Tuned 21XZ-R-img_1226.jpg   O.S. SPEED Tuned 21XZ-R-img_1228.jpg   O.S. SPEED Tuned 21XZ-R-img_1229.jpg   O.S. SPEED Tuned 21XZ-R-img_1227.jpg
ace16 is offline   Reply With Quote
Old 11-28-2013, 04:43 AM   #314
choisan's Avatar
anyone knows the size of the r2101 bearings? are they the same as XZ-R?
choisan is online now   Reply With Quote
Old 11-30-2013, 05:00 AM   #315
Thumbs up
Front
os #23731020
SPECS: Outer Diameter: 19mm
Inner Diameter: 7mm
Thickness: 6mm
Rear
os #23730020
SPECS: Inner Diameter: (14mm)
Outer Diameter: (25.4mm)
Thickness: (6mm)
