Like Tree3Likes
Old 06-26-2013, 02:07 PM   #286
The THS is a dual chamber design and I paid $70 for it. The 2080 was $170 at all of the places I checked, but I'll admit I did not search eBay for it.
rossb is offline   Reply With Quote
Old 07-05-2013, 10:47 PM   #287
IQ0
IQ0's Avatar
Default Flame out
just finished breaking-in this eng last week and today the eng run prefectly norm until when tried to push it at full throttle, then it went flame out. Have tried couple of times again and results the same. Running temp 85-90 degC..using Nova 2052 pipe. Any expert advise?
IQ0 is offline   Reply With Quote
Old 07-06-2013, 03:29 AM   #288
Phil Trotta's Avatar
Check your clutchbell. Make sure not touching clutch shoe
Check low needle settings and idle circuit
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 07-07-2013, 06:03 PM   #289
It is just me, or is the 21-XZ-R really tight when new? I'm running a brand new Ofna 1/8th box with a new battery and my box is not able to spin the motor unless I really heat it up well (about 180 degrees) with a heat gun, even if I remove the plug.
http://www3.towerhobbies.com/cgi-bin...?&I=LXAXU4&P=7
I already put a serious amount of wear into my new starter wheel. I've never seen a new motor this tight.
Old 07-22-2013, 03:48 AM   #290
hyder's Avatar
You need to heat it up to about 100Degrees celsius and start the engine with your starter box. Make sure it is at BDC before you hit it on your starter box.
If that doesnt work, you need a more powerful starter box. Im using Mugen starter box, it has dual motors. No problem starting the engine for the 1st time.
.::.MBX6.::.MRX5.::.SCX-10.::.TLR22.::.Lab C02.::.
hyder is offline   Reply With Quote
Old 07-22-2013, 07:21 AM   #291
sm4100's Avatar
Send a message via Skype™ to sm4100
I have done the pre-brake in on the engine stand using the airplane starter to crank the propeller and in fact I had the same experience.
The engine was so tight that my big airplane starter was melting the coupling rubber flange.
You really have to heat up the engine nicely and crank it up while in BDC as said and make sure the mixture is rich so the excess of lubrication can help a little bit (and most importantly to avoid first turn scratches)
My engine even had a high pitch metallic sound during the first minutes run and I thought something was going wrong but gone after a while.
I have run 19 liters of 25% nitro on it without a single problem.
sm4100 is offline   Reply With Quote
Old 09-12-2013, 06:14 PM   #292
Get this or Picco Torque .21 EDOMOD X-Type?
ferrariGTR is offline   Reply With Quote
Old 09-12-2013, 07:49 PM   #293
choisan's Avatar
Dont suggest to buy this engine as it will launch a newer version after ifmar race in japan in mid oct unless you really need one to run
choisan is offline   Reply With Quote
Old 09-12-2013, 08:07 PM   #294
Oh, which is the newer version?
Old 09-13-2013, 04:40 AM   #295
choisan's Avatar
From my further purchase request of this engine from Japan, they said they won't be any. My speculation
Old 09-13-2013, 07:44 AM   #296
but they will come out new version of con rod
kyosho malaysia is offline   Reply With Quote
Old 09-27-2013, 09:04 AM   #297
Arahawak's Avatar
Trader Rating: 32 (100%+)
http://www.facebook.com/photo.php?fb...type=1&theater
New OS Speed Engines..
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 09-28-2013, 03:33 AM   #298
Super Moderator
Snowy's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Arahawak View Post
The Cooling Head looks nice. Would like to see some inside pictures and see what is different.
Might have to buy one at the track next week and do a quick run-in.
Racing Lines Magazine
Snowy is offline   Reply With Quote
Old 09-28-2013, 07:16 AM   #299
choisan's Avatar
i saw futaba in-stock now
Old 09-28-2013, 11:07 PM   #300
Arahawak's Avatar
