Like Tree3Likes
Old 10-05-2012, 02:43 PM   #241
Roelof's Avatar
Send a message via ICQ to Roelof
Without changes you could use a 6 plug but the normal formula is to take out a 0.1mm headshim with 16%.
I have inspected and messured my engine and I must say that I am impressed. I had to clean some rust from the crankshaft but the PS set and the bearings seems to be fine.
The Novarossi R7 rod (I have plenty) fits perfectly on the crankpin but so far I could messure it is 0.4mm shorter than the OS rod so without modifications it is not possible. Oh well, on the search for an original rod
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 11-01-2012, 03:51 PM   #242
bigredspeed's Avatar
Originally Posted by jensroland View Post
Hi experts
Here in north europe the onroad season is pretty much over, and the gear is cleaned and prepared for next season spring 2013.
In 2013 we are switching from 25 to 16 % nitro.
How am I going to change the headshimming on my Speed 21 XZ-R ... from the standard 0.3 mm to ?
And do I have to change to an other plug (have been using the standard RP7 with 25% nitro) because of the lower cooling of the 16% nitro ... the cooler plug RP8
Best wishes; Jens
Hi mate, just run as normal, you might find you might have slightly less power on exceleration but thats about it, and you will get better run time also, not that you need to worry about the OS to make 5 mins. so yeah run as normal. I had left over 16% in my garage and use that to run in my Speed motors. good Luck.
Tornado Racing Fuel and Product
Sanwa
XRAY RX8,ZAC OS SPEED XZR
XRAY X12,Muchmoore Fleta
Hudy, HEI international
bigredspeed is offline   Reply With Quote
Old 11-05-2012, 06:42 AM   #243
Default 12F carby
Hello, just asking if there is anyone who has a 12F carby from one their 12XZ motors who wants to sell. I'm doing a mod to another OS motor and would like to try this carby out. Cheers, Paul.
Kyosho RRR /futaba 3Pk/OS TG/Novarossi S12/ Savox/Soon 2B R4..
CRC xti / Orion R10 /Trinty D3.5 17.5t
TLR XXX-TCR basher...
Friday night, fight night....rc racing, that is
Team FTR.
volumex is offline   Reply With Quote
Old 12-10-2012, 12:57 AM   #244
sm4100's Avatar
Send a message via Skype™ to sm4100
Default Conrod play
Have checked my Tuned Speed after 4 Liters and the conrod play was 0.06mm
Running always RP7 plug, 25 nitro btw 90-95 temp. The engine is perfect but the play looks really too much in my opinion.
Any Nova will keep 0.03-0.04mm for long time
I should have measured the play when it was new but was too in a hurry to try it out that even forgot that step
Hope I won't have any surprise with the conrod as the engine is pretty new and I just use for weekend bashing on local track but will replace it as soon as it gets anything above 0.06mm
sm4100 is offline   Reply With Quote
Old 12-10-2012, 01:59 AM   #245
GREGORY!'s Avatar
do you feel that when the rod was new was tight?
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 12-10-2012, 07:38 AM   #246
sm4100's Avatar
Default Conrod play
It is quite possible because the bushing in the conrod is so smooth and sratchless also the crankshaft is like new no signs at all. I have done the brake-in so carefuly 1st on engine stand then one galon of rich and smooth running on track. The sleeve looks beautifuly shinny and smooth. There is no way just the conrod would be killed so quick. I will relax and keep one eye on it after every race.
Old 12-10-2012, 08:57 AM   #247
I change my MM OS conrod after 8 Lt and the old one was nearly new..
Mtx6,Reds WCS,Protoform,kopropo,contact tires.
tonyhalandri is offline   Reply With Quote
Old 12-10-2012, 09:17 AM   #248
GREGORY!'s Avatar
tony?are you that guy that did grooves with his MM OS at FRT?xxx
how good is it?
Old 01-10-2013, 06:17 PM   #249
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Some info and a question:
So i ordered a new XZ-r about a month ago and had a REAL tough time getting it to break in, burned up a box and it kept leaking out of the head gasket??? SO i set it aside and purchased a Kangaroo (i needed a back up anyway) . Well since I am trying to make the Pan Am nats next week i didnt want to bother messing with warranty and all of that hoopla. So i purchased a new piston and liner. Came in yesterday and it was not the same as the original. The new one had the chrome plating all the way into the port and was masked off for a perfect finish while the old one seemed like it had overspray of the plating into the port.. Also the bore finish was different, the original looked like a honed finish while the new one looks polished. Well this one is breaking in perfect and runs beautiful so far! just wanted to relay that information. I dont know what happened to the original one but it definitely had some dimensional issues.
Now for the question, I am headed to Homestead raceway next week and the straight is over 300' long!! from what i hear it is a engine killer what are some suggestions to help keep me from granading my engine? shims, fuel, gearing etc etc? Thanx in advance BTW i run VP 25%
MantisWorx is offline   Reply With Quote
Old 01-11-2013, 03:18 AM   #250
Grinder's Avatar
Don't run your engine too lean. Use a cold glowplug. You can also look at adding head clearance. Also have the engine fully broken in.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 01-11-2013, 09:10 AM   #251
MantisWorx's Avatar
Sounds good, kinda what i was thinking. What is your definition of fully broken in? I already added an extra silver shiim.
Old 01-14-2013, 09:16 AM   #252
Grinder's Avatar
The engine is fully run in when the piston does not feel tight at top dead center when you turn the crank over quickly by hand. You can turn the engine over slowly, and feel some tightness. This lasts for a longer time. Usually the engine is fully run in after 1 to 2 gallons.
Old 01-14-2013, 09:44 AM   #253
MantisWorx's Avatar
OK, well i am close , there is about 3.5mm of "polish" on the liner and with ARO i can turn it over with no plug but with the plug in its still pretty tight. a couple of tanks and i should be there. what are your thoughts on the third needle? Also how does this engine like to be geared? I can let it wind out or i can lug it, this track has a 300' straight? I had first gear really low on break in and it would blister the tires with anything over 50% throttle coming out of the turns, but didnt get a chance to test second gear and its been raining so I am pretty much going to have to dial it in at the track when i get to Florida.
Old 01-14-2013, 10:15 AM   #254
Rick Vessell's Avatar
Uriah is correct, you need to run it in more for it to be fully broken in. The fit on these is very snug when new so take your time and don't lean it too much. Top speed will come when it's broken in.
As for the 'third needle', leave it alone. Unless you have a great deal of tuning experience it's easy to get way off with settings when you start moving it.
The 'third needle' is actually the spray bar that the low speed needle goes into at idle and low speed. It also controls overall metering due to it's position in the venturi. They are set at the factory and any adjustment to them at the track is slight and has to be coupled with adjusting the other needles as well.
Keep the gearing conservative until it's broken in. Once it's freed up, you can let it rev more on the straight.
Rick Vessell is offline   Reply With Quote
Old 01-14-2013, 01:18 PM   #255
MantisWorx's Avatar
Thanx guys, wish me luck!
