Old 06-27-2012, 06:38 AM   #226
Hi guys,
Just purchased one f these bad boys! Whats the best pipe and header by novarossi for this engine? 2015 2025 3006? 5,6,7fin header?
Capricorn LAB C02
Protoform
Futaba
Sirio
xray man is offline   Reply With Quote
Old 06-27-2012, 11:46 AM   #227
Rick Vessell's Avatar
Originally Posted by xray man View Post
Hi guys,
The O.S. T-2080 pipe is the best for the engine if it's available. If you run a Novarossi pipe, run the 2015.
Futaba, O.S. Engines, Trakpower, HB Racing, SpeedPassion USA, Eggroll Inc., Vesselli Racing
Rick Vessell is offline   Reply With Quote
Old 07-09-2012, 06:28 AM   #228
HPC
Hi guys,
What temperature do u guys race this engine at?
HPC is offline   Reply With Quote
Old 07-13-2012, 08:06 AM   #229
Piyo Piyo's Avatar
Originally Posted by HPC View Post
Hi guys,
I usually run at 105deg C ideally, max at 110deg C.
The engine can take punishment up to 125deg C, but you will lose considerable power at this range although better fuel consumption.
VIOLA ARIELLE & FLOREN ISABELLE
Piyo Piyo is offline   Reply With Quote
Old 07-14-2012, 09:31 AM   #230
HPC
Thanks for the response. I ve been running it below 110 deg C....was just wondering if I shud be running it higher,as I think the Novas do run at a higher temp.
Once again, Thanks!
Old 07-17-2012, 02:24 AM   #231
Do nova plugs fit these motors? If so whats the best to run?
Capricorn LAB C02
Protoform
Futaba
Sirio
Old 08-01-2012, 01:01 AM   #232
???anyone
Thanks in advance
Capricorn LAB C02
Protoform
Futaba
Sirio
Old 08-01-2012, 01:23 AM   #233
I don't recommend nova plugs on OS engines. Tried it before and the seating of the turbo cone doesn't sit flush in the OS top plate.
peppernick is offline   Reply With Quote
Old 08-07-2012, 02:38 AM   #234
Okay thanks for the heads up!
Capricorn LAB C02
Protoform
Futaba
Sirio
Old 08-25-2012, 08:15 AM   #235
drstrangelove's Avatar
Hi Guys,
I just bought OS Speed 21XZ-R and the 2080 tune pipe for my Serpent GT car. Now I realised the 2080 manifold is not pointing correctly. Any of you guys using this engine on the GT car? Do I need to purchase the offroad manifold, ie the 2060 manifold and use it with the 2080 silencer?
thanks in advance
Accepting sponsors who need to test their products durability :)
drstrangelove is offline   Reply With Quote
Old 10-04-2012, 04:50 AM   #236
Roelof's Avatar
Send a message via ICQ to Roelof
I have bought an used car with this engine. It has runned about 4 liters so I want to replace the rod but the OS onroad is not sold and supported that well in the Netherlands.
Searching on the partnumber I also come to the rod of a VZB buggy engine which seems to be the same. Is this true? I know some shops over here selling OS offroad engines.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 10-04-2012, 07:36 AM   #237
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
Yes, it is the same rod
tl2111 is offline   Reply With Quote
Old 10-04-2012, 08:19 AM   #238
Roelof's Avatar
Thanx! It should not be a problem to get one over here....
Old 10-05-2012, 12:37 PM   #239
Hi experts
Here in north europe the onroad season is pretty much over, and the gear is cleaned and prepared for next season spring 2013.
In 2013 we are switching from 25 to 16 % nitro.
How am I going to change the headshimming on my Speed 21 XZ-R ... from the standard 0.3 mm to ?
And do I have to change to an other plug (have been using the standard RP7 with 25% nitro) because of the lower cooling of the 16% nitro ... the cooler plug RP8
Best wishes; Jens
jensroland is offline   Reply With Quote
Old 10-05-2012, 01:23 PM   #240
stefan's Avatar
Send a message via AIM to stefan
Originally Posted by jensroland View Post
Hi experts
Best wishes; Jens
Hi Jens,
I'd just try the engine as it is with the 16%.
stefan is offline   Reply With Quote
SEO by vBSEO 3.5.0
