Like Tree3Likes
Old 09-28-2011, 04:10 PM   #151
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Originally Posted by ralphierace13 View Post
does anyone know the differance between the 2080 and 2080sc pipe
Hi Mate,
The 2080sc using the conventional 3 spring connection (between the manifold and pipe).
The 2080 uses the new OS "clamp" connection.
Besides this connection, both pipes are identical.
Michael_T is offline   Reply With Quote
Old 09-29-2011, 10:07 AM   #152
Originally Posted by Michael_T View Post
Hi Mate,
Roumors in Japan said that os will cut the production of 2080....
Mtx6,Reds WCS,Protoform,kopropo,contact tires.
tonyhalandri is offline   Reply With Quote
Old 09-29-2011, 06:28 PM   #153
Michael_T's Avatar
There is quiet a big jump in price between the 2080 and 2080sc.
Using Tower as a reference:
2080 = $169.99
2080sc = $199.99
$30 more for such a small change in the connection type only??
OS are cheap on engines, but difiently make it up in accessories
If you right, better get in quick and get the 2080...
Old 09-30-2011, 05:20 AM   #154
bigredspeed's Avatar
2058 sirio pipe works also very good, comparing to the 2052 nova pipe, the sirio pipe makes the engine very aggressive on the bottom end and also LOUD...lol but 2052 with the short pipe makes the engine smooth, unfortunately with some of the testing i have done the with the nova pipe, only the short manifold works... picco pipes work well also...
Tornado Racing Fuel and Product
Sanwa
XRAY RX8,ZAC OS SPEED XZR
XRAY X12,Muchmoore Fleta
Hudy, HEI international
bigredspeed is offline   Reply With Quote
Old 10-01-2011, 09:06 PM   #155
GREGORY!'s Avatar
how about nova 2015?
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 10-02-2011, 03:29 AM   #156
yes the 2015 will work, but depending on track.i mentioned 2052 in my last post but i was meaning 2015, i used it on a fast flowing track with a short header from memory and the engine was smooth with good power., but sirio pipe will make the motor aggressive on the bottom.. 2052 i used on my local track and i really was not happy with it...
Sanwa
Old 10-03-2011, 09:31 AM   #157
you will surprise nova 2007 with 5 fins header in long track
kyosho malaysia is offline   Reply With Quote
Old 10-03-2011, 01:31 PM   #158
Thanks kyosho, will try the 2007 pipe.
Sanwa
Old 10-05-2011, 02:49 PM   #159
major3d's Avatar
Originally Posted by PROVK View Post
Use it to run in the engine
Is everyone using the break in shim?
TKI2, SPEKTRUM PRO, .21 SPEED
major3d is offline   Reply With Quote
Old 10-05-2011, 08:40 PM   #160
i dont use the extra 2mm shim that comes with the engine but i do add a extra 1mm, and i leave it in there.. that way you do not over compress the engine my opinion...
Sanwa
Old 10-06-2011, 01:28 AM   #161
jv
We never use additional shims, because the standard compression rate is OK for 25% nitro fuel. If you check the compression with solder you will read about 0,65mm which is a lot more than other engines use. But of course the squish is different etc. Sometimes when we need more punch we put 0,1mm less to get around 0,55mm.
We always use RP7 glow plug.
The best pipe for the SPEED is the original OS...tested all many times on many tracks, but the result is always the same.
Best regards,
Jernej
www.toprc.eu
...feel special...
jv is offline   Reply With Quote
Old 10-08-2011, 05:31 AM   #162
azcau's Avatar
Does anyone know if the Nova Kangaroo crankcase will swap into the XZ-R? I have a cracked crankcase on my XZ-R due to it being dropped but the rest of it is in A1 condition and I have a couple of old Novarossi crankcases in the Frankenstein box.
Mugen MRX5/Novarossi/GRP/Spektrum/RB Fuel
www.MRCCR.com
azcau is offline   Reply With Quote
Old 10-09-2011, 11:36 PM   #163
Chances are mate the ports will not line up with case, so you gona have to measure the liner, if you want i have a ZX-R version 1 that is still running with heaps comp left in to get you out of trouble and just use the case if you want.. PM me if your keen to buy it..
Sanwa
Old 10-10-2011, 02:19 AM   #164
azcau's Avatar
Thanks Bigredspeed. It don't matter the OS crank doesn't fit in the Nova crankcase so end of storey. I'll pm you.
www.MRCCR.com
Old 10-15-2011, 09:11 AM   #165
Default Conrod
Anyone knows, where can I get the Speed XZ-R conrod? I mean in stock, this conrod is very hard to find. Or any replacement? Thx!
GP: Capricorn C03 1/10 touring, Capricorn C803 1/8 onroad
Engine: Tesla .12 WC, Tesla .21 7 port on-road, Rody VS02, OS 2101
beebone is offline   Reply With Quote
