Old 09-18-2004, 03:08 PM   #1
Default 6 or 6.5mm carb
Is there a 6 or 6.5mm carb available for a nsr 5 ports engine by nova rossi ? I know that rody rb v12 3 or 5 ports uses 6 or 6.5mm carb, hence would like to try one for the nsr 5 ports.
xtreme888 is offline   Reply With Quote
Old 09-18-2004, 04:10 PM   #2
teammpp's Avatar
Should be able to just stick the Rody carb straight on direct.
Think you might be able to get a 6mm or 6.5mm restrictor for nova engines too. have you tried Ted Longshaw?
teammpp is offline   Reply With Quote
Old 09-19-2004, 06:41 AM   #3
Pyramid's Avatar
The nicest I've seen is from Mspeeed (Japan) made of aluminum with a very high proffesional polish finishing. Range is 5.5, 6, and 6.5mm.
Pyramid is offline   Reply With Quote
Converting Rotary Carb to Slide Carb? hrnts69 Nitro Off-Road 1 07-18-2008 11:29 AM
WTB 11L ROTARY CARB FOR .18TZ, HAVE NEW SLIDE CARB TO TRADE? SHAGGS R/C Items: Wanted to Buy 0 12-01-2006 02:34 PM
Sirio .12 with Novarossie Carb -CX12 carb fit? au_Nightmare Onroad Nitro Engine Zone 10 09-25-2004 08:29 AM
Sirio .12 with Novarossie Carb -CX12 carb fit? au_Nightmare Nitro On-Road 5 12-15-2003 02:24 PM
Cx-12 carb TRF_TG10R Nitro On-Road 8 05-15-2003 12:42 PM
SEO by vBSEO 3.5.0
