which kind of Tune pipe is better?
hello,
who can tell me, which kind of Tune pipe is better?
thin or thick?
thin or thick?
hi. the capacity of a tune pipe should be 8 to 15 times the displacement of your engine. so if you are running a .12 size engine your pipes capacity should be between 16 to 30 cc.
Also a shorter tune pipe should give you more top end, while a longer pipe should give a broader power range. ofcourse what pipe is best for an engine larger depends on the type of engine.
i hope this helps.
i hope this helps.
Are the RD logics pipes any good for 1/8th on-road?
