Need Help with Stuck Sleeve!!!
ok, i tried pulling the sleeve out of my rs12s2, but its stuck, i heated it up with my heat gun,and i got it out half way, but no more, and since i didn't want to use any more force, i thought there was something wrong. It just won't budge now, up or down, the piston moves freely up and down, but the sleeve is stickin halway outta the engine! The engine has about 13 tanks on it. My dad suggested i wait until the engine cools down to room temp to move it back down, then heat it up again from that temp,and pull it all the way out, i also can't twist it either. please help! heres a pic to help you.
I had the same problem with my Picco last week. What I did was drop the piston down and then moved it over so that whenI turned the shaft, the piston hit the bottom edge of the sleeve and pushed it the rest of the way out. It's probably not the best thing to do to the piston, but it worked.
Re: Need Help with Stuck Sleeve!!!
Have the same problem with my new motor, Have to give this a try.
I tried the zip tie trick. The sleeve kept slicing it off.
You need a BIG zip tie, one like you'd use as a tank pull.
You can also use the handle of an old toothbrush to do the same thing as the ziptie
Even zip ties can damage the edge of the really soft pistons we use nowdays. Since you got the sleeve that far out, find something you can set on the top edge of the engine case next to the sleeve to use as a fulcrum. Then get a wide blade screwdriver and lift it out from the bottom of the lip on the sleeve. I typically won't use the word "pry" but essentially that is what you will be doing. Just be smart about using the fulcrum and you will not damage anything.
The only time this hasn't worked for me was when I had sleeves that were cracked all the way around the transfer ports. Then you'll be lucky to get it out at all because the edges of the sleve dig into the inside of the case like fishing hook barbs.
Preheat the oven to 270 degree and place your engine inside for 5 to 10 minutes. Take it out and you can easy to remove the sleeve. Pls don't put any salt ...
