.12 engine for $100 to $200?
Is there any decent .12 engine I can buy from $100 to $200? I'm in a tight budget, i do race on a short and long tracks?:tire:
Last weekend I helped someone testing a Novarossi N12T1 and I must say it is a big bang for that price but it is not competive with the high end engines although it differs not that much.
Originally Posted by Roelof
(Post 8091954)
but its only 135 dollars plus 6 dollars for shipping off ebay. |
RB TOURING JUNIOR 10 great motor run's really well and holds its own on short track on long track not so well
Originally Posted by td-civ
(Post 8092073)
If you're looking for a good engine, you're going to have to spend the extra cash for something good. If it was only on a short track where 2nd gearing isnt getting close to topping out, then the N12 would still be good. But since you also race on a track that is larger, then you definitely should get a good engine. You can't beat the price of the RB T10 package - plenty of power and cheap-ish as well. |
You staying to race in TC or just passing by the class?
Originally Posted by DJ_Shakespear
(Post 8092126)
+1 for that.
If you're looking for a good engine, you're going to have to spend the extra cash for something good. If it was only on a short track where 2nd gearing isnt getting close to topping out, then the N12 would still be good. But since you also race on a track that is larger, then you definitely should get a good engine. You can't beat the price of the RB T10 package - plenty of power and cheap-ish as well. Ultimately with budget engines, they should last long enough for you to save up for the Race "DONK" and take good care of it, GRP bundles are great value, but if you're going to lean them up to chase the Novas and RB's then you'll wear thru it really quickly and you'll be up for more $$. OS perhaps?? Not too lean, not too rich!! Care for it and it'll run for ages. Then buy the best RB or NR you can get your hands on! |
Picco JLR .12's. Lots of go for very little dough.
I wouldnt get the JLR .12, they just won't last. I had 2 JLRs, both blew rods very early and the P/S never lasted more than 6 months. 2 engines, can't be a coincidence, though the rod metal was very poor. I would either get an RB Junior, Nova N12, or a GRP bundle if you don't race with the pros. Think of this:
Cheap engine = not cheap in the long run + not that powerful. Good engine = 300-400 at least + pipeset. Kick-ass engine = good driving and setup! :D + knowledge of tuning and chassis adjustments. You can come first with an RTR engine as long as your car is setup correctly and you are consistant. If you spend too much money on engines and still don't win, you will always be last. |
*sigh* I miss my Ninja. Tuned right, that motor had wings that would shock you. Initial pinch was hard on rods, to be sure. If you can spring for a combo pack and have some patience, you'll be all right
