Old 10-15-2010, 10:59 AM   #1
Default running rear exhaust
I have an aftermarket rear exhaust it is a 3 chamber but I am running it on a side exhaust engine which you can image causes a huge length in tubing to get from motor to exhaust. Am I creating a problem by doing this?
Blue0234 is offline   Reply With Quote
Old 10-15-2010, 03:43 PM   #2
helivaguy's Avatar
Trader Rating: 42 (100%+)
If you increase the length in between the manifold and pipe, the engine will get better low rpm power(more torque) but you will loose high rpm power(less rpm at full speed).
If you decrease the length in between the manifold and pipe, the engine will get better high rpm power(more rpm at full speed) but you will loose low rpm power(less torque).
The only thing that is "still like new" is the box it came in..
Only a half gallon through it my Ass!
helivaguy is offline   Reply With Quote
NTC3 Rear Exhaust Pipe options? DookieBooty Nitro On-Road 17 10-14-2002 09:40 AM
Recommended .12 rear exhaust engines coolrcdad Nitro On-Road 32 08-01-2002 12:02 PM
Ofnas new rear exhaust 12 line of engines Foger Rox Nitro On-Road 14 03-20-2002 10:20 PM
SEO by vBSEO 3.5.0
