.12 side exhuast & manifold
do they still make engines with a side exhuast?
i have a fw05, and looking at a engine with a side exhuast? other option is to run rear exhuast, but then ill need one of those 'U' shaped manifold (like off-road) for .12 engine? does anyone know where i can get a 'U' shaped manifold for .12? |
Do you have a picture of the layout? It seems like perhaps the engine is mounted like on off-road where the spur gear and clutch bell point toward the front of the car and the flywheel is sideways?
Originally Posted by Dredd
(Post 7936062)
i found a 'U' shape manifold, but costs $54 :| http://www3.towerhobbies.com/cgi-bin...P?I=LXKBH4&P=8 as for side port .12, the only one i cant seem to find anything that is still being made today. how will a top-end engine run with a 'U' shape manifold? |
i found a .12 U shape manifold laying around, but it doesnt have any attachments to attach to tuned pipes
-looks like this http://ecx.images-amazon.com/images/I/31631146MJL.jpg it attachs to the pipe via a rubber coupling, and tuned pipes have that massive ring around the attachment which the rubber coupling cant fit over. |
You'd need a pipe that is simply tapered at the end and it attaches to that manifold with a rubber tubing and some zip ties. Not like the usual springs and rubber ring.
yeah i have a tapered kyosho pipe and a U shaped manifold, wonder how it will run on other engines.
how bout i just f*n bolt on a .30 wankel rotary sideways. that would have a side exhaust wouldnt it? |
you never know until you try it how a pipe will perform with a given engine.
side xhaust engn from nova
http://www.amainhobbies.com/product_...ug-Rotary-Carb http://www.amainhobbies.com/product_...ug-Rotary-Carb |
yes i saw that, but i want one with a circle exhaust port so i can mount the standard manifolds to it.
Something like this?
http://www.shengines.com/spare%20par...ase/TE0711.jpg There aren't any and beside that, I do not think you will find a manifold for it. |
yep.
i just found that u can get a adaptor to run the round manifolds. other option is to run normal rear exhuast engines and use a OS 'u' shape manifold.. which costs like 50$. http://www3.towerhobbies.com/cgi-bin...P?I=LXKBH4&P=8 |
