Old 06-19-2004, 07:31 AM   #1
Default .12 engine break in...
I just put a new sleeve and piston in my motor. It's only and associated .12, nothing fancy. Any break in tips?
I did lube everything when I put it back together so it's not dry or anything.
elmar66 is offline   Reply With Quote
Old 06-30-2004, 01:15 PM   #2
Trader Rating: 15 (100%+)
Send a message via AIM to stebog
I'm sure you already started your break-in, if you're impatient like I am, but here's what I used on my last 2 engines.
stebog is offline   Reply With Quote
Old 06-30-2004, 03:08 PM   #3
Techart27's Avatar
Break in tips:
Be patient
let the engine cool between tanks
Put a few drops of high quality after-run oil before starting it for the first time
Do a few tanks of idle and few more with slow driving (number varies with engines, be on the safer side by doing more )
After break in, take glow plug out and put around 8 drops of after run oil in, then give it a few tugs or if ur using a starter box give it a spin.
hope this helps
Techart27 is offline   Reply With Quote
How not to break in an engine ! Maximo Nitro Off-Road 4 08-05-2008 09:34 PM
engine break in 37 RACING Nitro Off-Road 10 03-15-2008 02:25 PM
Engine break-in ? acsubie Electric Off-Road 3 05-11-2007 07:42 PM
How do you break in an engine? joe of loath Rookie Zone 12 03-26-2007 03:08 AM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 10:49 PM
SEO by vBSEO 3.5.0
