Old 05-21-2004, 08:12 PM   #1
Default Fuel pressure
Hey all ive got a Savage 25 and Ive got an exhaust leak. Without the exhaust pressure the engine starts then dies, it dosnt feed it enough gas and makes it run really hot. Where can all the possible leaks be??
DrIfT'R' is offline   Reply With Quote
Old 05-21-2004, 08:36 PM   #2
corvettecrazy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to corvettecrazy
missing screw
cooling head
not sealing tight (cause is being screwed down wrong normally)
hole in pressure line
tank top not sealing
crack in tank
corvettecrazy is offline   Reply With Quote
Return fuel tubing length - how to lower pressure in tank charlesd Onroad Nitro Engine Zone 3 06-13-2008 10:32 PM
Need help with no fuel pressure problem pumpkinfish Nitro Off-Road 12 08-05-2007 09:44 AM
fuel pressure problem 32819toon Onroad Nitro Engine Zone 17 05-06-2007 07:19 AM
pressure line to the fuel tank?? kris NZ Rookie Zone 9 07-31-2005 11:58 PM
Pressure inside fuel tank... Raycer Nitro On-Road 10 06-10-2004 01:25 AM
SEO by vBSEO 3.5.0
