OS TR engine thread
Old 02-11-2005, 11:59 AM
  #526
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Originally posted by uaerc
Hi
I used the stock p6 when i ran in and used it for quite some time till i switched to the p8 on a race day and i think it held in there really well for 3 cont. day of racing just one plug.....on the 3rd day i ran the car with a broken silicone pipe on the exhaust which would lean out my car when i was on the straights thats when i had to pull over and shot out..after that day i converted my fw05r to RR and ran my car yesterday it wouldnt start ihad to change the plug i have moved to p6 again since it was stock. so lets see how the p6 really runs.......since its winter here.... i want to try the hot lpugs.
i converted my 05r to the rr and i love it !!
Marcos.J is offline
Old 02-11-2005, 06:33 PM
  #527
InitialD's Avatar
You should with the amount of money spent. (j/k)
InitialD is offline
Old 02-11-2005, 07:28 PM
  #528
Super Moderator
Marcos.J's Avatar
i know it cost me a woping $65.00 !!
Marcos.J is offline
Old 02-12-2005, 05:48 AM
  #529
uaerc's Avatar
Talking
4000 whooping Yens !! for me !!
I would be converting my RRR to the WC with the 1pc engine mount, uni shafts and carbon front stay.
uaerc is offline
Old 02-12-2005, 02:32 PM
  #530
danjoy25's Avatar
Trader Rating: 38 (100%+)
Default OS TR12 Efra version
Just tried one yesterday and it was holding its own against all the JPs, Nova and other top end engines, I also qualified 4th quickest out of 50 runners and also had atleast a quarter left in the tank after 5 minutes heat. I am very please with this engine and of course the price
danjoy25 is offline
Old 02-18-2005, 11:19 AM
  #531
uaerc's Avatar
Default OS TR leaning out.....
Hi guys
just a quick qs.. I started my TR - T today after almost a month today and the engine was running just fine......but suddenly there was a problem with it........... the engine would suddenly lean out and loose power....... only sometimes at full throttle.....i dont think its lean...
could it be some kind of a leak ?
uaerc is offline
Old 02-18-2005, 02:32 PM
  #532
FUK_WRX's Avatar
Default Re: OS TR leaning out.....
Hi guys
try this get one of those engine sprays from orion, start the motor and spray it where the carby is attached (neck) if it stalls or changes the rev the seals may be broken or the carby is not mounted properly. Try taking the carby off the crank case and re-intall secure it properly with your thumb and tighten the nut, you might as well change the o-ring on the neck to make sure.
FUK_WRX is offline
Old 02-23-2005, 01:37 PM
  #533
nsxshogun's Avatar
Same is happining to me. I was out running and I was slowly getting up to full throttle. By the time i was at Full the engine like died and came back to life.
nsxshogun is offline
Old 02-26-2005, 11:36 PM
  #534
rcabj's Avatar
could be your plug mate.....anyway check for leaks.............
rcabj is offline
Old 02-27-2005, 06:32 AM
  #535
nsxshogun's Avatar
True when the street dries up Ill change plugs. I still have the plug that came with it in.
Old 03-07-2005, 07:52 PM
  #536
Darth Vader's Avatar
Default dyno chart
Hi guys,
I am currently using the TR(P)-T 5-port.
I would like to know if any of you have the dyno chart/graph.
I saw the review in one of the magazines recently and I am quite sure that there's a dyno chart for this engine.
Would be interesting to have the dyno chart to help on gearing calculations.
If any of you have one for this engine, can you please post it here?
Cheers.
Darth Vader is offline
Old 03-10-2005, 05:22 PM
  #537
Trader Rating: 15 (94%+)
Default os .12 tr turbo button ?
hello
Just wanted to know where the best place is to buy the turbo button for the os .12 tr 5 port engine ?
preferably an online store as i live in australia
thank you
John
mrgsr is offline
Old 03-15-2005, 07:24 AM
  #538
Tire Chunker's Avatar
Trader Rating: 16 (100%+)
Default OS TR 12 Rotary Carb
Guys anyone have an old TR .12 with rotary carb that they are not using and looking to sell. PAYPAL if you have one.
[email protected]
Tire Chunker is offline
Old 03-28-2005, 08:18 PM
  #539
Moderator
Clegg's Avatar
So today I went to break in my new OS TR 5p Turbo plant. Using O'Donnel 20% race fuel and the OS recommended needle settings per the little booklet, and all I got was a hellishly flooded motor.
You guys have any specific recommendations for breaking in these plants? (I stripped a pulley in my starter box so I have a few days to reaserch till I get the replacement in)
I am also getting an OS 7 plug in since in my experience a Medium plug is better for breaking in.
Theres like 530 posts in this thread, and the forum software's search logic is ass, so its a PITA to search back and see any specific post with a break-in run down.
Clegg is offline
Old 03-28-2005, 08:43 PM
  #540
nsxshogun's Avatar
Lean out the HIghend needle until you can get it to fire.
