Proper clutch shoe removal and install?
Guys _ I bought an already built Kanai 2 off ebay - the car was primo, but the builder didn't tighten down the clutch/flywheel sufficiently and it loosened when I tried to start it first time. The motor is very tight and it backfired and twiched the retaining nut.
That means I had to remove the clutch shoes et al to tighten the nut.........just checking - when looking at the motor from the shaft end back to the cylinder - (head on) - which way do the shoes go if the clutch shoe shafts/pins are at 8 12 and 4 o'clock? I think the 8 o'clock clutch shoe lays from the pin at 8 up to 12 basically
as the motor spins counter clockwise - is this correct?
thanks for your answer to a dumb question -
Re: Proper clutch shoe removal and install?
Yup.... that is exactly correct - I got home from work and
layed out the pieces - you can't put it together backwards
it just don't fit backwards - there's only one way to make
the springs line up with the grove in the nut, I learned working
on motorcycles that if it doesn't go together smoothly, you're probably screwing it up - everything fits like a glove
thanks for your advice.
by the way, what is an easier way to install the shoes?? my shoes almost broken after 2xtimes installation.
Originally posted by mckrooz
Hehe, I don't think there is an easy way to get them on. I hated putting on those shoes. Gotta love the centax.
sorry for too many questions.....
N
