Old 04-02-2004, 12:16 PM   #1
Default Review or Opinion: Team Orion .12 ROAR
Does anyone have any experience w/ this motor. Anyone know who actually makes it for Orion? Was thinking about putting this in my R40.
80051 Team Orion .12 ROAR - Rear exhaust, SG shaft, Slide Carburator
RPM: 37,000 - HP: 1.45 Bore: 13.8 - Stroke: 14.0
Orion Wasp .12 ROAR
FEATURES: Rear round exhaust opening with rubber gasket installed.
Slide valve carb insures good on-road performance (see COMMENTS).
Crankshaft is threaded on inside for pilot shaft clutch
INCLUDES: One Wasp .12 Roar Nitro Powered Engine with slide valve carburetor,
pinch bolt and nut for attaching carb, parts list and instruction
REQUIRES: Medium temperature glow plug.
Tuned Pipe.
Header, depends on type and brand of vehicle.
Fuel with at least 18% lubricant and 10-20% nitro. Most of the fuels
we carry meet or exceed the lubricant content required for optimum
performance and maximum engine life. In the past, the conventional
lubricant content in fuel was 18%. But with new technologies
fuels like Red Alert and O'Donnell for example, have a better
quality of lubricants even though the percentages of lubricant
are lower. These high-tech lubricants provide exceptional cooling
and protection.
SPECS: Displacement: 0.129cu in (2.11cc)
Horsepower: 1.45bhp @ 37,000 RPM
Bore: 0.54" (13.8mm)
Stroke: 0.55" (14.0mm)
Carburetor Settings:
High Speed Needle Valve: 1-1.5 turns from closed
Low Speed Needle Valve: 3-3.5 turns from closed
Exhaust opening: 0.59" (15mm)
Distance between mounting holes opposite side:
1.24" (31.5mm)
Distance between mounting holes same side: 0.47" (12mm)
Distance from top of head to bottom of mounting flanges: 2.91" (74mm)
Distance from top of head to bottom of crankcase: 3.38" (86mm)
Distance from bottom of flanges to crankcase bottom: 0.47" (12mm)
Distance from back of engine to end of crankshaft: 3.46" (88mm)
Distance between mounting flanges: 1.53" (39mm)
M Polo is offline   Reply With Quote
Old 04-02-2004, 04:49 PM   #2
stefan's Avatar
Send a message via AIM to stefan
It's a Picco XP 12. Great engine if you can tune it.
It needs thourough sealing around the carb and the backplate.
It's fast as hell though..
stefan is offline   Reply With Quote
Old 04-02-2004, 07:16 PM   #3
nitrodude's Avatar
What Stefan said. But I dont recomend them, the one I had didnt last as long as the Novarossi based engines I have had. The carb is a major POS. One good thing to do to that engines is to drop a Nova carb on it. It makes easier to tune, and it runs faster too.
Steven Muller
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 04-02-2004, 08:34 PM   #4
I appreciate the response. Fast or not, I don't want to pay $170 for a motor thats kind of picky tuning wise and has a crap carb.
Thanks again!
Old 04-04-2004, 10:06 AM   #5
Send a message via ICQ to markallen Send a message via Yahoo to markallen
I have the Ofna/Picco version but haven't run it yet.I had already
decided on changing the carb anyway.I'll let you guys know how it runs.
markallen is offline   Reply With Quote
Old 04-16-2004, 03:21 AM   #6
Ybakoff's Avatar
Mine goes really well, After I took the carby of and changed it for a novarossi carb,
But I had the same problem with an sts I brought for club racing.
The novarossi carb fixed that as well.
But the motor goes well. But you will prob have carb problems after a while.
Ybakoff is offline   Reply With Quote
Old 04-17-2004, 12:25 AM   #7
mckrooz's Avatar
Send a message via AIM to mckrooz
Like everyone said, the carb is junk. It is pretty fast. Good torque and bottom end.
Kyosho RRR Evo2
mckrooz is offline   Reply With Quote
HobbyPlex Roar Race Review Tire Chunker Electric On-Road 38 03-19-2008 01:14 PM
Team Orion Wasp .12 Roar legal wild gopher Electric Off-Road 6 04-23-2004 06:48 AM
Team Orion Wasp Roar .12 wild gopher Onroad Nitro Engine Zone 1 04-22-2004 05:15 PM
Kyosho 1/8 Suzuki Motorcycle With Team Orion Coreless Motor And Team Orion Flash Esc hpidriver R/C Items: For Sale/Trade 3 07-04-2003 06:56 PM
Team ORION Wasp .12 ROAR ?? Nexus Nitro On-Road 7 04-25-2003 08:06 AM
SEO by vBSEO 3.5.0
