Old 09-06-2009, 07:29 PM   #1
PrimeAKF11's Avatar
Default Heat range of the new OS RP plugs
Does anyone know how the new RP plugs compare to the old P plugs? I am looking for something that compares to a P7 (medium) plug. I thought I could just get a RP7 since I assumed the heat ranges between old and new plugs were comparable but I noticed that OS now says RP6 is medium (P6 was a hot plug).
Did OS just change their 'heat scale' (how hot they think a X plug is) around, or are the plugs actually different? Because, even though that RP6 is now called a medium plug, if its heat range is anywhere close to that of a P6 I don't want it. Way too hot for my liking.
Best rubber tires>> www.SweepRacingUSA.com
For your Team Magic G4 parts needs>> www.bluesunhobbies.com
HD Videos of Blue Diamond Onroad Raceway!!! 200ft+ straight of fury!! >> http://www.rctech.net/forum/racing-forum/406318-2nd-annual-pete-johnson-have-nice-day-memorial-race-5.html
PrimeAKF11 is offline   Reply With Quote
Old 09-06-2009, 08:11 PM   #2
wingracer's Avatar
Trader Rating: 21 (100%+)
I am not familiar with the new plugs but the number generally refers to the wire size of the coil. Typically 5 hot, 6 medium, 7 cold, 8 very cold. Some refer to them differently, like 5 very hot, 6 hot, etc. but the coil (and thus the heat range) is about the same.
Sean. Certified speed crazed mowron.
Team Shepherd USA
wingracer is offline   Reply With Quote
Old 09-07-2009, 03:50 AM   #3
bluef250's Avatar
go to osengines.com and you will find info on glow plugs
bluef250 is offline   Reply With Quote
SEO by vBSEO 3.5.0
