Palmaris engine thread
#1051
Re: Kyosho Cup A2
Originally posted by kitracer
NS12 crankcase with higher induction timming.
#1052
Re: Re: Kyosho Cup A2
Originally posted by InitialD
Chris, what do you mean by "higher induction timing"? Is this done on the crankshaft to advance timing earlier? How does this affect the engine performance in general? Better top end? Thanks.
#1053
Re: Re: Re: Kyosho Cup A2
U got PM
U got PM
#1054
Originally posted by xtreme888
Hi Ed and Chris,
Horrible rain in South of England...the track dried out slowly, hence traction was not that good. My throttle problem disapperared after changing fuel....went from byron to runner time. BRB p/s set in NSR. lap time were about 14.5, where was manually counted as transponder system was not set up. The two person who finished ahead of me last time were now following my trial of smoke !!!! One was using a new jp 5 ports and another a nova rossi 7 ports !!! Man this p/s set is excellent, i was able to pull away in the corners so fast, and also i let them pass and then overtake them on the fastest parts of the track !!! temp was around 168`F with # 6 nova rossi short plug.
Ed, what temp would you think that is the optimun running temp for this BRB set.
Ed gonna need a set for the 3.5cc !!!!!!
philip
Hi Ed and Chris,
philip
I do have 21 sets right now-I sent you PM earlier, so please let me know.
Edward
#1055
Originally posted by cdelong
what is a "BRB" p&s set?
I do have for 12 and 21 sizes. It is proven to be more dependeble, powerfull and much longer lasting. Try to read all this tread-there is lot of info-too much to put now.
Edward
#1056
Originally posted by Top Gun 777
Hi Phillip. Nice to hear that you like BRB set. I guess you have older version and newer version much stronger.
#1057
Ed, do you have a pic to show a new and a old version? Any differences?
If you look your set from exhaust windows of crancase and you see bottom line of exhaust port of sleeve-you have new version, if it is look like original-old version.
#1058
#1059
Thanks for the info Ed. BTW, do you also make BRB piston sleeves for Novarossi RR12L3/L5 long stroke engines?
If real demand, we can easily make it.
#1060
philip
philip
I sent you PM 4 days ago and you still didn't read it.
Best regards
Edward
#1062
Re: hotel
Originally posted by Speedypeterb
hey Edward, left you a pm about hotel confirmation let me know or Todd if you read this you could let me know thanks will be racing state race this weekend will let you know on results talk to you later, Peter
#1063
Hi Ed,
What different do the height of between the new and old sleeve have on the performance of the engine. From my understanding if the height of the ports of the new one are higher....would that mean more top end or have got it the wrong way round, and i am sure there is more to that !!! If you don`t mind, would you explain how the old and new sleeves will affect performance.
Cya
Philip
p.s check pm as well
Cya
Philip
#1064
Top Gun 777
Ed,
Forgot to ask you, BRB p/s set for 3.5cc, have that been designed for large open or small tight tracks? Although it is designed for nova rossi based engine, which crankcase was all the experiements and testing carried out on ? What crankcase would be the best for this ? From my experience i seem to found that the REX version is the best one out of all the nova rossi !!!!
#1065
Hi Ed,
Cya
Philip
Hi Ed,
Cya
Philip
If I will tell what difference done on new style I will shoot my legs. New style has smaller ports and it makes realy big difference. They are smaller, but timings stay untouched-we make it smaller from bottom, not from top.
Old style is basecaly calculated area t flow ammount, velocity for event. On new style we use different effect then just pressure of crances pushing mixture to combustion chamber, it doesn't mean we don't use pressure, it means we use other effects then just pressure. In our particular case, we are not depending of OEM and we don't have to moddify stuff from market, we are designing, making and testing stuff on the spot. It is veru difficult to explane what we are doing ( will take a lot of space and I will need to disclose a lot of info), but we are working on every possible direction on flow and material properties.
In general old style and new style has the same run time, but new design has much more power on all around the range.
