Sirio S21 CL7 R STI
Sirio S21 CL7 R STI
Anyone knows the factory carb settings for this engine?
Thanks in advance.
Thanks in advance.
Well, I had a bad day yesterday at the track.. switch malfunctioned and my car got away on the straight away... this same engine.. the conrod stretched and the piston dragged.
Regarding the carb, there is no real factory setting, it can differ a lot regarding exhaust, and fuel. If you can start is just adjust it where needed.
Most of the time with engines is setting all needles to flush to make it startable.
Regarding the switch, do not use one!
Just use a male-female connector like a Futaba servoplug and just let it hang somewhere without sticking it to the chassis or servo. Also use a spring or a small hairband on the carburator, when loosing power it will pull the carb to a close position.
Umm.. but would the hairband be strong enough to pull the servo back ?
Depending the servo.... I suppose running such an engine you are using better servo's. The better servo's run light and are easy to handle by a hairband.
