JP WC21 R1 Kangaroo
JP WC21 R1 Kangaroo
Anyone has anythought on this one?
Hey Ah10
It's a JP, it's a great motor!
Seriously, I've used this engine and it's very good and reliable, it also produces lots of power across the rev range. A very good choice of engine.
Originally posted by ND
Hey Ah10
Hey Ah10
may be like powerband, usable rpm and such.
So far I felt the JP has more rpm but less torque the reason I said that is because I have gear it down to let her rev to get some insane speed and power, on the same token, on the max I could gear it higher and still have enough torque to push taller gearing. That's what I notice so far! And also seems like the Max has more bottomend power compare with JP because I need to set the centex engage later to achieve the same off the line speed!
Anyone give me some input?
I run a JP, Just finaly found a new one!
I like them, kinda touchy on the bottom, but runs well. more importantly, I am sorta rough on engines, and this one appears to hold up well. I get allot of great rip out of it, but mostly I like the durability I have seen so far from it.
