Motorcycle two-stroke oil for added oil in nitro fuel
I know some use oil from the drugstore, we call it "wonder oil". It is just a plain castor oil.
If you just add a tiny little bit to much oil, the result might be that your engine flames out all the time when going on throttle... (i've seen it happen, and the engine get's stuck at TDC every time....)
I wonder why you want to add oil... what about just running the engine rich!
Lee
