Old 12-22-2015, 05:06 AM   #301
Great thread...after 2 years playing with these little engines I finally get it
Serpent 977
jtrmx250 is offline   Reply With Quote
Old 05-05-2016, 09:56 PM   #302
Trader Rating: 55 (100%+)
Help me out here I think I'm experiencing what in this article is called lean bog. I notice it after about 5-6 minutes of running. My engine is the alpha lutz worlds edition I was coming off the track about 240. I've richened up the hsn as per the article says, coming off about 210 and it still lean bogs when getting low on fuel. I don't wanna richen anymore I'll start losing performance and temps will lower I'd like to be able to run it at 240 for racing. What can I do to rectify this issues is it possibly something else causing the issue??
AE B6 17.5, AE B6 Mod, AE T5m 17.5
Stephan81 is offline   Reply With Quote
Old 05-06-2016, 10:22 AM   #303
lil-bump's Avatar
Trader Rating: 83 (100%+)
This is the onroad forum but I will give it a shot. Have you replaced the fuel tank? it could be the lid on the tank is not properly sealing causing a lean bog when the tank gets low.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 05-06-2016, 11:41 AM   #304
nitrodude's Avatar
Where on the track is it bogging?
Could also be that the engine is old, when they start to wear out they will run good for a few minutes then loose performance.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 05-23-2016, 05:12 PM   #305
Hi guys, I just watched this video
https://www.youtube.com/watch?v=rUBCDQHDb3g
and what this guys states near the end of the video that the idle should come down after 1o seconds and the settle. From what I am hearing when the car stops it idles up then down and then down again.
other guys say that after stopping the idle should go down instantly and stay consistent.
Is this guys wrong?
Italo2275 is offline   Reply With Quote
Old 05-23-2016, 08:08 PM   #306
RoketRdr's Avatar
Is this guys wrong?
Yes he's completely wrong. If your idle hangs after a WOT run and then drops its because you're too lean on the HSN. If you're car drops to normal idle and then begins to idle up after that then your LSN is too lean. Any time your idle hangs or goes up on its own you're too lean on the top end or bottom end. If you're car idles down normally then up and down again like you said then you need to be checking for air leaks in your fuel system, carb and engine. I suspect your have a bad fuel tank cap seal. With a proper tune your engine should immediately drop to idle after WOT and stay there. After about 10 seconds it should start to blubber and richen up then almost die. At no time should your idle increase or hang on its own.
TeamC GT8 - REDS R5 - Buku Clutch - RCShox
RC8.2 - Nova +21-4BTT - Buku Clutch
RC8.2e - Tekin T8 Gen 2 1900 w/ RX8 Gen 2 - RCShox
Highly modded Revo
Airtronics MT-4 w/ Radiopost servo's
RoketRdr is offline   Reply With Quote
Old 05-25-2016, 05:46 PM   #307
Thanks for the response that video was confusing me
Old 05-25-2016, 09:44 PM   #308
dan_vector's Avatar
Trader Rating: 27 (100%+)
I wouldn't say he is completely wrong!! Those guys are factory Reds and Kyosho team and a very very quick driver with lots of top end results.
There are two trains of thought relating to engine setup. The method in the video is the 2 stage idle technique and has its merits however the method described by RoketRdr is also valid.
My preference is the 2-stage as I find the engine generally has more punch out of corners and is better (cleaner?) off the line. The engine is also more reliable and less likely to stop in the event of a crash leading to the car being upside down while the marshal gets to you.
As I said both have merits and this is why you've heard different folk recommend a different thing. I see more engines setup by the 2 stage idle method than anything else.
To say Elliot's mechanic is wrong however is absolutely not the case.
Having said that they are discussing offroad engines!! Now we can talk about onroad setup which is slightly different.
Here we do look for the engine to drop to idle quickly but the size of the engine also matters. For example a.12 engine will have a tenancy for the idle to run on after WOT on the straight for example. This is normal as long as it returns to idle within around 2-3 seconds. The bigger engines shouldn't run on however.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 08-06-2016, 05:30 PM   #309
hvychevy94's Avatar
Good evening, I'm having a problem tuning the Picco .21 otto engine. It idles good but when I give it gas it stays at a high idle for about 5 to 10 seconds and then it will come back down. It seems like it stays at a high rev for too long.
hvychevy94 is offline   Reply With Quote
Old 04-18-2017, 12:05 AM   #310
Default Tuning bible for 1/8 on road clutches?
Is there a tunning bible for 1/8 on road clutches?
Ted Su(TW) is offline   Reply With Quote
Old 04-18-2017, 01:12 AM   #311
https://youtu.be/aYNzdzQnlzY
Old 04-25-2017, 12:18 AM   #312
sm4100's Avatar
Send a message via Skype™ to sm4100
Open the HSN 1/4 and run another laps and see how long the idle will be high until it drops again. If does not make any difference you might be having the self turning HSN syndrome which happens quite frequently in (.21 and above) engines when the HSN seat is worn out or the o'rings are square (too old). When this condition happens although you might always set the needle right, after running the engine high revs the HSN starts closing spontaneously due to very high vibration frequency and leaning the engine overall fuel flow and makes you think the LSN is wrong. If you want to know if you have a self turning HSN just mark the needle position with a pen marker and run feel laps. if the needle is moving even a bit, replace either the o'rings or the whole needle seat. The best way to test this is set the carburetor to the factory settings or any settings you remember the engine will be rich enough to start easily and check the engine behavior from cold to hot and see if the HSN will turn. This is one of the reasons most airplanes have a ratchet on the HSN, it is easy to do small increments and also prevents the needle to turn spontaneously under high vibration.
sm4100 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
