Like Tree22Likes
Old 05-07-2006, 12:09 AM   #1366
Team Kamikaze's Avatar
Originally Posted by ziggy12345
Less than 1!!!!!
It might had something to do with the clutch bearing going at the same time and also the plug went and might have dumped some trash in the bearing.
I see the bearing is a 16002. RC mushroom has the 16001 which looks the same bearing but not ceramic. Anybody know where I can get the 16002?
Cheers
I got the bearings for any Nova Rossi base engine in stock
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 05-09-2006, 12:43 PM   #1367
ziggy12345's Avatar
How do i get the back bearing out of the 35PLUS21? The bore in the crankcase is 15.5 mm and the bearing is 15.5mm so you cant get a tool in to tap it out. Is there a bearing puller that I can get to pull it out? I dont see how as there is nothing to grab hold of!!
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 05-09-2006, 12:52 PM   #1368
Cheers
the bearing size is 26mm O D x 14.5mm I D x 6mm thickness where did you get the measurement of 15.5mm ???????
Old 05-09-2006, 01:42 PM   #1369
revzalot's Avatar
Have you tried sticking in an oven for 5-6 minutes preheated at 325 degrees? Use the handle of a wooden spoon to tap the bearings out.
www.revzalotmotorsports.com
revzalot is offline   Reply With Quote
Old 05-11-2006, 10:40 AM   #1370
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Default Top Issue with compression
Welp I've been running the top for about say 13 tanks or so on 30%byrons race blend, previously broken in with 20% Odonnell, and I noticed I could turn the engine over withmy index finger and thumb. There is a bit of pinch there, so upon inspection of the engine everything seems fine in there - no scratches, no worn parts, etc. I realized who ever assembled the engine, slipped two bronze shims under the big metal one. One appears to be .2mm and the other is .1mm. I removed the .1mm and noticed there was a bit more to the pinch at the top. The engine never seemed to clear out when the #6 RB was in there, but the Nova #7 CTFS worked great. Think any detonation will occur? I was going to start the engine a while back when it was warm out and I did get some sort of backfire as the car blasted my friend in the face with a puft of smoke/air. Any ideas guys? Should I remove that other .2mm shim and leave the normal silver shim in there? I know others ran their engines with no shims and just cooler plugs withmore success and that article stating sometime shims aren't necessary? Then again when I had my engine it did have quite a lot of compression.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 05-11-2006, 10:55 AM   #1371
Jamie Corrado's Avatar
Bert,
You should not be removing any shims from under the head. When making the switch to 30% you should be adding at least a .10 shim. The more you remove the better chance you have at a detonation senario. Put all the shims back in and retune.
Jamie Corrado is offline   Reply With Quote
Old 05-11-2006, 11:01 AM   #1372
HarKonnenD's Avatar
Jaime,
Thnx. I'll add it back in then. What about the compression issue? I never really had an engine that was fairly easy to turn over by hand like it before..then again it does run fine. So leave well enough alone eh?
Old 05-11-2006, 11:54 AM   #1373
Originally Posted by HarKonnenD
Jaime,
Bert,
As far as how the compression feels, don't worry too much, it's usually a sign of a well seated piston/sleeve. Remember, if the pinch at TDC is really tight, the engine will run hot and not make the power it should.
I usually am concerned more with connecting rod/wristpin/clips,than I am about piston/sleeve.
Old 05-11-2006, 12:18 PM   #1374
HarKonnenD's Avatar
Jaime,
Sounds great! Thanks a bunch! I got worried for a sec. Everything back to normal and car been rebuilt ready for another run when I get more fuel in. Unfortunately they may not carry byrons due to the fact they want to send 8 cases instead of 4. My LHS doesn't have room for 8 cases. The other option is Odonnels 30% and Blue Thunder 30%. I may give OD a whirl.
Old 05-11-2006, 01:31 PM   #1375
Jaime,
Tell Tony to stop being cheap and order the 8 cases, there's room in the basement.
I have run every fuel out there and always went back to Byron/Mugen fuel. IMO there is nothing better.
Old 05-11-2006, 03:09 PM   #1376
Default Novamega sx12rt ms
I've done a thread search and couldn't find much info...
Does anyone know if there are still parts for novamega sx12rt available?
I picked one up used. i'm just getting into nitro. any help would be greatly appreciated.
Dodgersfan is offline   Reply With Quote
Old 05-11-2006, 03:42 PM   #1377
HarKonnenD's Avatar
Jaime - That's what I've been thinking! I personally found byrons to run the best in all of my engines compared to the other stuff. I really would dislike going back to odonnells especially smelling the nasty fumes.
Old 05-12-2006, 08:28 AM   #1378
Mnster's Avatar
Anyone know where I can find the needle settings for a CX .12 with slide carb?
Mnster is offline   Reply With Quote
Old 05-12-2006, 09:09 AM   #1379
teammpp's Avatar
Cheers
Use your oven. Get the case nice and hot and then just tap the case on something. Bearing will come out a lot easier.
teammpp is offline   Reply With Quote
Old 05-12-2006, 11:16 AM   #1380
...guess not...
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
