Novarossi engines thread
#121
I have a NSR12S3, and it is the same as the Nova Mega with the MCPiston & sleeve...It's a bad mamajama!
#122
Originally posted by Motorman
funny you ask that because I am slightly miffed at novarossi's current lettering system, I thought the R was a rotary carb version but I could be wrong. However I think I can saftly say that if it is an NS version it has the billet piston. I used to have a very good handle on it all but its gettin a little fuzzy now that i'm not into new customer motors every day.
Oddly enouth the NS's we get here are marked
NS12S3-A1
NS12S3-A1
I could be wrong though...
But I guess the NS isnt succeed product, performance is really convincing. The challenge is very hard to break this engine right. NSR is much easier.
About the NS12S3-A1 Im as confuse as you...
Maybe we better wait the "DR" engine.. right ?
#123
NS12S3
I'm kind of a noob to messing around with the internals of Nitro Motors so be gentle.
I have an NS12S3 in standard trim and since ROAR is allowing turbo plugs this year (insert assumption here) all I have to do is replace the head button with a turbo one and obviously get a turbo plug.
Is this correct?
If so.....who sells the head button?
Thanks for your input!!
Kevin
Is this correct?
Kevin
#125
Re: NS12S3
You mean standard plug ?
I never had this kind engine, can you tell me the type in the box?
Is this correct?
Kevin
Is this correct?
Kevin
This is the number :
NRS-28605 LARGER UNDERHEAD FOR TURBO GLOWPLUG
Pls ask your LHS
#126
To RoyU
Also, I picked up a NSR12S5 engine and I was wondering if ysou could tell me if its a long or short stroke engine and there's also an "L3" stamped on the head, do you know what it stands for. I know this your thread, but if you don't mind.
If in the box is stated NSR12S5, you should have S5 stamped in the headsink. If it L3 the engine should be RR12L3
NSR is normal stroke, ideal for med to big track and L3 is perfect weapon for tight technical track.
#127
Thanks Goldfinger
On the box its labled "NSR12S5". The top of the head is stamped "Race L3" no "S5". Any idea as to why Novarossi is labling the engine this way?
#128
Originally posted by RoyU
Thanks Goldfinger
Thanks Goldfinger
Pls consult with your lhs.
#129
what is he difference between the nsr12s5 and the ns12s5?
#130
Originally posted by GoldFinger
Could be wrong heatsink only and/or wrong engine.
#131
I hope its not the wrong engine
Coz it was a black and white mistake from novarossi.
#132
#133
Ok, I'm starting to get a little pissed. I know that somewhere on this planet there has to be a p/s and turbo button for my NS3!!!
email [email protected]
#134
You can take a look at:
http://rc-mushroom.com/
or contact my LHS :
http://www.modelsport.nl/webshop/
I know he has the P/S and also Novamega and maybe Novarossi turbobuttons
#135
RC Mushroom doesn't have them...they were my first try.
I looked at your shop's website, but couldn't find anything listed (I had to use a translator page). I sent them an email, I hope they can read it. BTW: I'm not trying to be a smart a**, but I've found quite a few sites that do not have anyone to answer questions in English.
