Like Tree21Likes
Old 02-18-2006, 12:51 AM   #1231
ziggy12345's Avatar
Novarossi have raised their prices to the distributers 10% this season so look at a 15% price hike to us minions I will only get NR engines if its by far the best.
I have a 35PLUS 21
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 02-18-2006, 04:30 PM   #1232
I guess it's time to retire my 03
Originally Posted by jeffreylin
It is stock. It's rather hard to tune as for some reason the top needle is a lot more sensitive. I was told that the top needle is more blunt so it's more sensitive but I went on Nova's web site and it shows the same part as the 321P.
Performance wise, I think acceleration especially mid range is surperior than the JP. Top end is also a little faster but that could be just tuning.
slide_228 is offline   Reply With Quote
Old 02-18-2006, 07:35 PM   #1233
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Any of you guys just run on huge tracks? The track I'll be running at is bridgeport CT, which isn't that big. Figure the top would be enough, but thinking of that RB C3 piston sleeve and if it will make my engine weaker than it is or faster if I put it in. I'd receive a great price on it...less than $100.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 02-19-2006, 07:55 AM   #1234
rge63's Avatar
Anybody try a sts12 rod in there novarossi's?(rear port .12's)
rge63 is offline   Reply With Quote
Old 02-19-2006, 08:29 AM   #1235
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
maybe the opposite....
but who would spend money in a good and reliable engine and then put a poor spare part when relacement is needed....?
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 02-19-2006, 08:32 AM   #1236
HarKonnenD's Avatar
Sal-Any advice on my situation? Should I just get new engine later or something, or try that RB C3 p/s set for like $50 in my top?
Old 02-19-2006, 08:46 AM   #1237
can't tell what difference on performance will be noticed..........
if you're thinking of buying a new engine than stick with your top and enjoy it till you get a new one.......
Salvadori Racing
Old 02-19-2006, 07:03 PM   #1238
Trader Rating: 15 (100%+)
I noticed that the carb on my old X12 has three adjustments and the new one only has two. Why is that?? Would I be better off using the carb off of the old engine on the new one?
THE DOCTOR is offline   Reply With Quote
Old 02-20-2006, 11:32 AM   #1239
jag
jag's Avatar
Default Pipe
Which ROAR legal pipe/header is recommended for a Rex RER S3 on a fairly large fast track?
Thanks,
jag
jag is offline   Reply With Quote
Old 02-20-2006, 12:15 PM   #1240
jeffreylin's Avatar
R/C Tech Charter Subscriber
Thanks,
jag
Skyline is really good and probably your best bet. Otherwise the Sirio pipe is good too but it's expensive and hard to find.
jeffreylin is offline   Reply With Quote
Old 02-20-2006, 02:45 PM   #1241
any brand EFRA 2601 with short (5 fins) conical manifold.......
Salvadori Racing
Old 02-20-2006, 04:51 PM   #1242
Talking looking for engine.
Hi all,
I am planning to buy an engine for my new MTX-4. I need some advise for getting the most. Here are the facts:
-IFMAR legal. 3 port carb. 5.5 max
-nitro 20%
-9.252 feet (running in Quito)
-no modifications to piston or sleeve.
Thx.
Antolinez is offline   Reply With Quote
Old 02-21-2006, 09:19 PM   #1243
HarKonnenD's Avatar
Awesome the RB p/s set is definately going to be purchased for the top. I'm also going to get the RB pipe later on too.
Old 02-22-2006, 11:59 PM   #1244
Roger's Avatar
Hey gang. Gotta question. I ran my car today ( MTX-4 ) at my local track and noticed that my engine ( Rex RS3 ) kept on cutting off at about the 3.5 minute mark. This was after the break-in process. I tried changing the glow plug to a #7 and it did the same thing. These are some of the factors im using for this Rex .12 RS3 motor:
1) Fuel: New Byron 30%
2) Plugs: NovaRossi 6 and 7
3) Motor temps: 210-230 degrees F
The motor is new and I just broke it in today. Break-in process:
1) 2 tanks at idle with factory settings ( 15 minute cool down between intervals allowing piston/sleeve expand and contract ).
2) 3-6 tanks ( drove the car by blipping the throttle around the track never hitting full throttle while maintaining and monitoring engine temps ( 150, 160, 170, 180, 190, 200 degrees F ). 10 minute cool down between each tank.
3) 7-15 tanks: started to lean out needles while maintaining tempertures ( 210-230 degrees )
Any ideas on whats going on ? Thanks guys.
Roger Serafin
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 02-23-2006, 05:29 AM   #1245
your LSN is probably extremely rich........with your car on the bench start the engine and when it reach its working temperature hit full throttle for 2~3 seconds and let it idle...........if after 10 seconds you can't get a smooth acceleration of the engine stalls the LSN is rich........proceed the same way until you get a smooth acceleration and the engine RPM stay consistent when idling for 20~30 seconds........
Salvadori Racing
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
