Like Tree8Likes
Old 01-25-2006, 08:30 AM   #1156
asw7576's Avatar
Default novarossi ns15s5
I'm looking to buy complete p/s/r part number: 08275 for novarossi ns15 s5. where is it ?
datasheet: http://www.novarossi.it/images/esplosi/NS15S5.pdf
Old 01-25-2006, 04:07 PM   #1157
jjmudd's Avatar
Anyone with suggestions as to how to keep a 421B engine running for longer than 5 minutes? A bunch of bought this engine and it just wont run for any of us. We've tried medium to hot plugs but nothing works...at idle engine flames out when hot.
jjmudd is offline   Reply With Quote
Old 01-26-2006, 06:05 PM   #1158
Speed_Racer's Avatar
Default Which NovaRossi parts wil work in a NovaMega EVO4?
Was wondering which NovaRossi parts (piston/sleeve/bearings/crank) are interchangable with the NovaMega EVO4 MS?
Is it possible to use a P5 case with on-road Piston/Sleeve and use it for on-road?
Is it ok to use a off-road engine for on-road?
Speed_Racer is offline   Reply With Quote
Old 01-28-2006, 12:59 PM   #1159
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
crankshaft is also different..............the carburettor as well, but i think you can tune the engine with the offroad carb......
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 01-29-2006, 11:13 PM   #1160
kitracer's Avatar
Try using a longer manifold or more angle one.
Nitro-x Tomorrow Fuel today
Blitz body the champion choice
kitracer is offline   Reply With Quote
Old 01-30-2006, 02:10 AM   #1161
Thx for differentiating the tuned and normal version.
Another question? what's the difference between 2015, 2017, 2018, 9901 & 9886 pipes?
Thx.
aztecz is offline   Reply With Quote
Old 01-30-2006, 09:31 AM   #1162
jjmudd's Avatar
I'll give it a try. Thanks.
Old 02-01-2006, 03:19 PM   #1163
Trader Rating: 12 (93%+)
Default where to buy novarossi
hi
where is the best place to buy novarossi engines from ?
i am after a novarossi NS12S3
thanks
John
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 02-02-2006, 04:57 AM   #1164
Hi guys! Does anyone know the factory needle setting for the NOVA P5X Buggy engine? Thanks in advance!
OrAnGe PoWeR is offline   Reply With Quote
Old 02-02-2006, 05:22 AM   #1165
i can't answer you're other questions but i have seen a few off road 21's used at our track. the powerband is lower in the rpm range and they don't have the same top end but they work. the smaller the track the better they will do.
sedanaddict is offline   Reply With Quote
Old 02-02-2006, 01:39 PM   #1166
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Default Please help!
I'll be using byrons 30% fuel soon, but I don't have any info on my Novarossi PT21 SP1 engine as to how many mm and how many shims to use for it. It's an older top engine as seen here:
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 02-02-2006, 02:03 PM   #1167
as far as I know every .21 engine is properly set to use 25% nitro (except for rally game versions).......you should be safe with 30% but if you really want to avind any risk put another 0.10mm shim........
Salvadori Racing
Old 02-02-2006, 02:04 PM   #1168
HarKonnenD's Avatar
Lightbulb
Sounds good I'll get two just incase. Thanks a lot!
Old 02-02-2006, 02:15 PM   #1169
if you set the head clearance too big you end up leaning the engine too much to get a good performance and it will be dificult to get it running at reasonable temps...........
Salvadori Racing
Old 02-02-2006, 05:58 PM   #1170
HarKonnenD's Avatar
Lightbulb
When I ment two I ment an xtra one just incase. What can happen then if I run it with 30% stock will there be any signs I should look out for? I'll take the head off to see if there are any shims on there.
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
