Old 12-09-2005, 05:29 AM   #1111
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
stay with 16%.....................castor is always nedeed, but 2% is more than enough............synthetic, depending on its quality from 5 to 10% is ok..........
if you can't find 16% fuel, use 20%........
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 12-09-2005, 02:06 PM   #1112
I will be making my own with Coolpower for the synthetic oil.
josh_c is offline   Reply With Quote
Old 12-09-2005, 08:00 PM   #1113
where do you find nitromethane at reasonable prices?????
Salvadori Racing
Old 12-10-2005, 07:29 PM   #1114
rge63's Avatar
So who has the best deals on nova engines.
rge63 is offline   Reply With Quote
Old 12-11-2005, 04:43 AM   #1115
A good place to get the novarossi is from www.rcmart.com. cheap
Old 12-11-2005, 05:45 AM   #1116
suntok2's Avatar
Send a message via ICQ to suntok2 Send a message via AIM to suntok2 Send a message via Yahoo to suntok2
www.dogboneind.com
suntok2 is offline   Reply With Quote
Old 12-11-2005, 09:55 PM   #1117
phantom-racing's Avatar
hey guys, I have a novarossi ns12 3 port and having issue with starting the engine. I just send the p&s for resizing and now the engine does not starts. I tried the factory setting lsn 2.25 out hsn 3.5 out and still no go. the turbo plug is fine and tried several, it does get fuel to it and it spins fine but no ignition. of course the glow ignitor is working also. tried different shims from 3mm to 6mm but still not firing. I have tried to richen the needles by up to 2 turns low and high but no go. piston and sleeves looks fine as well.
anyone has any suggestions?
thankx
phantom-racing is offline   Reply With Quote
Old 12-11-2005, 09:57 PM   #1118
Jye
whats some of you guys favorite .12 engine from novarossi, including rex and top versions. and whats you all's favorite modifed novarossi .12's.. talkin 3 ports...
Jye is offline   Reply With Quote
Old 12-11-2005, 10:09 PM   #1119
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
If you live in the USA, buy from a US dealer.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 12-12-2005, 05:56 AM   #1120
rge63's Avatar
thankx
Did you try putting some fuel straight into the cylinder? take plug out and pour just a little in... it should start... I have had a fresh engines does this... It may take a couple times.. something (oil etc) is blocking fuel flow usually after it starts a couple times it will solve the problem
Old 12-12-2005, 07:39 AM   #1121
I did pour fuel as well but no luck.
Old 12-12-2005, 07:56 AM   #1122
Hesky's Avatar
do you get compression as soon as the piston starts to close the exhaust port?
checkin for fuel blockage is also worth doing, take the glow plug out and spin the motor, if your at factory rich settings you'll hopefully see a visible spray of fuel exiting out the glow plug hole.
Hesky is offline   Reply With Quote
Old 12-12-2005, 07:04 PM   #1123
Trader Rating: 15 (100%+)
I have a Mugen X12 with the grey head, is the piston and sleeve still available for this engine? I don't want the micro cast piston. Any part numbers? Anyone know where it is available?
THE DOCTOR is offline   Reply With Quote
Old 12-12-2005, 07:47 PM   #1124
I just got one a few days ago. It is part #08606. That is the X12 billet piston/sleeve. Try contacting nitrohouse or ace. They probably won't have it, but I know that Mugen does stock them. They have conrods as well if you need one. Part 07601
Old 12-12-2005, 08:10 PM   #1125
Chewdogg's Avatar
Doc I have the newer x12 with the turbo button and the part number is NOV08606 (competition piston/sleeve). Not sure if its microcast or not. I would try mugen to be sure (949) 707-5607.
Also here is the part number (F08613B) for the piston/sleeve & rod set I run in my stock X12 and JPX12. It is the JP-FX12 modified piston and sleeve. This is what I have been running all year.
Troy
Chewdogg is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 11:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 06:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 11:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 06:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 07:28 PM
SEO by vBSEO 3.5.0
