Like Tree32Likes
Old 01-21-2004, 07:57 AM   #91
ziggy12345's Avatar
Where can i get a new piston and liner for a Novarossi NSR3?
Cheers
ziggy12345 is offline   Reply With Quote
Old 01-21-2004, 08:02 AM   #92
afm
afm's Avatar
Default Re: NSR 12S3
Originally posted by Finken
What is the difference between NSR 12S3 and NS 12S3, and do they use same cylinder/piston??
That's exactly the difference between them, the NSR uses the new MCP (Micro Cast Piston) P/S technology, which allows the engine to withstand higher RPM's/Temp.
AFM
afm is offline   Reply With Quote
Old 01-21-2004, 08:37 AM   #93
ziggy12345's Avatar
Will a new NSR piston and liner fir the NS3?
Cheers
Old 01-21-2004, 08:45 AM   #94
afm
afm's Avatar
Cheers
YES!!!
afm
Old 01-21-2004, 09:23 AM   #95
ziggy12345's Avatar
Cheers
Anybody?
Old 01-21-2004, 09:37 AM   #96
afm
afm's Avatar
Cheers
Have you tried RCMushroom????
AFM
Old 01-21-2004, 10:28 AM   #97
modellor's Avatar
Give Top Gun a pm. He can get you hooked up probably
modellor is offline   Reply With Quote
Old 01-21-2004, 01:05 PM   #98
ok, i understand that the NSR liker higher temps, BUT the oil dosnt lubricate very good at temps of 150 C does it? It vaporise faster, right?
Finken is offline   Reply With Quote
Old 01-21-2004, 01:48 PM   #99
Corse-R's Avatar
NSR's like fuels with higher Castor oil content to withstand the higher temperatures he likes to run...
Castor burns at higher temperatures and still lubricates where Synthetic oils burned some time ago.... Will recomend you a quick pass on the Fuels thread, put some interesting points there.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 01-25-2004, 05:36 PM   #100
Hi Guys,
I will soon be getting myself an NSR12 S3 and I'd like to know what plugs you would recommend to use for my conditions. I generally run in temperatures around 20 degrees C (however the colder months will be here in a few months) and my track is very large, permenant track built to cater for 1/8th and 1/5th scale (up there with the largest straights in the country). I'm also using 16% Nitro.
I previously had an NS3 for a short time in which I ran the C6TC plugs.
Thanks.
R J M is offline   Reply With Quote
Old 01-26-2004, 09:56 AM   #101
Corse-R's Avatar
Originally posted by R J M
Hi Guys,
I run too in very large tracks and mine setup for this engine doesn't differs so much of the usual setup of the engine. Just pay some attention to:
Plugs: C5Tc or C6Tc
Fuel: 16% Nitro, 10% oil as minimum. I custom blend mine own fuel and use different oils depending on the temperature, just check the fuel thread to get more information.
Combustion chamber size: As Motorman said many time ago, adjust it to measure .014" high (measure it with the tin lead and measure how high is the wire after being crushed by the piston to the plug button).
Doesn't matter how long is the track, with the correct gearing and exhaust configuration, the engine really shines on big tracks.
Cheers,
Corse-R
Old 01-26-2004, 10:10 AM   #102
stefan's Avatar
Send a message via AIM to stefan
Corse, check you e-mail regarding 2nd room for Ft.Myers
stefan is offline   Reply With Quote
Old 01-27-2004, 04:08 AM   #103
Corse-R's Avatar
Surely you have a voice mail in your mobile phone regarding this...
Cheers,
Corse-R
Old 01-31-2004, 04:03 PM   #104
Guys,
Would a 'dint' in the pipe affect performance at all?
My pipe is a little bit dinted (pushed in) at the stinger and I'm just curious if this would have a detrimental effect on performance.
Thanks.
Old 01-31-2004, 06:59 PM   #105
Guys,
Thanks.
My experience, small "dent" will make your engine leans.
But a veri big dent will make your engine goes whoooaaa.. very rich.
Im not so sure why. Maybe because the change of the resonance that effect the engine timing.
GoldFinger is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
