Old 04-03-2005, 07:12 PM   #781
cdelong's Avatar
no sweat. some guys have told me they use solder since it is so soft, but i don't want to risk binding anything in the engine by using solder.
i guess the advantage of using solder is that you can bend the solder into a "L" shape, and stick it in the plug hole without taking the head off.
i'll take the extra 5 minutes to remove the head twice and use the clay. i'll usually remove the sleeve afterwards to ensure no clay got stuck in any ports.
cdelong is offline   Reply With Quote
Old 04-07-2005, 09:36 AM   #782
I would say the new .12 Novarossi will be hit on street during June and the price is like $270. Some have poxyed shaft included.
smash123 is offline   Reply With Quote
Old 04-07-2005, 10:22 AM   #783
spenzalii's Avatar
Send a message via AIM to spenzalii
Quick Question,
I just became the owner of a NSR12S5. Since it was used, I took it apart, chcked everything out, lubed it with after run oil and put it back together. What should be the starting needle positions on this engine? I have no idea how it was tuned and don't want to take a chance. Also, would a hot turbo plug be recommended with this engine?
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 04-07-2005, 10:32 AM   #784
teammpp's Avatar
Originally posted by spenzalii
Quick Question,
Mine was about 5 turns out on HSN and 3 turns out on LSN.
teammpp is offline   Reply With Quote
Old 04-07-2005, 01:31 PM   #785
spenzalii's Avatar
Thank you. Does Palmaris have a p/s set for this engine? Just in case...
Old 04-07-2005, 01:56 PM   #786
teammpp's Avatar
yep. I actually run my BRB set in that case. Works great.
Old 04-07-2005, 02:05 PM   #787
impalabob64's Avatar
Send a message via AIM to impalabob64
Default jp black rs12 s1
i just dropped this motor in my fw05r, ballistic can i get some feed back on this eng. it faster than my ns3 race motor , this thing sounds like a chainsaw
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 04-07-2005, 02:12 PM   #788
Chewdogg's Avatar
Anyone know if the new nova 12's will be released before the sedan nats in July.
Chewdogg is offline   Reply With Quote
Old 04-07-2005, 02:23 PM   #789
teammpp's Avatar
The way things are going at the minute it'll be touch and go. The Team drivers havent even got theirs yet
Old 04-14-2005, 07:38 AM   #790
tommi's Avatar
Default Info on NSR12S5 head clearance...
Hi guys, could use some help here as I haven't got any tools available with me right now. Can anyone give me the head clearance measurement for the NSR12S5 with the stock silver shim? TIA!
tommi is offline   Reply With Quote
Old 04-14-2005, 04:14 PM   #791
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
0.50mm........
you can go with a 0.10mm shim for 16 and 20% nitro......and two 0.10mm shims for 30% nitro.......
the original shim doesn't make the engine consistent.....
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 04-14-2005, 09:30 PM   #792
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
Default Re: Info on NSR12S5 head clearance...
stock silver shim is .3mm (i think)
Old 04-15-2005, 04:32 AM   #793
Default Re: Re: Info on NSR12S5 head clearance...
the shim is 0.30mm............the HEAD CLEARANCE is 0.50mm
Salvadori Racing
Old 04-15-2005, 07:01 AM   #794
cdelong's Avatar
Default Re: Re: Re: Info on NSR12S5 head clearance...
I think a lot of people here confuse shim thickness with head clearance. They are not the same as pointed out by SR above.
You never know what your real head clearance is unless you check it. Do not just assume 0.3mm shim will do the job. Check your clearance at least once. You can calculate your clearance from there if you keep track of your shims at any given time.
Old 04-15-2005, 07:37 AM   #795
tommi's Avatar
Thanks guys, appreciate your inputs.
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 11:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 06:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 11:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 06:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 07:28 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
