Like Tree32Likes
Old 01-09-2005, 11:37 AM   #676
asw7576's Avatar
Lets bet small amount ? I said the manual book is not up to date, perhaps it was published earlier than ns15s5 and ns12. How much do you want to bet ?
Btw, while my engine is under your supervision, why don't you check together the possibility of using ns12s5 piston, sleeve and conrod ? If not possible, then please order the complete set for ns15s5.
...... I've done crazy mod today I really enlarge the intake port very big !!!
Old 01-09-2005, 06:27 PM   #677
InitialD's Avatar
Originally posted by asw7576
What I meant is this ( best case scenario ) :
I don't mind my NS15 will become NS12 after engine overhaul. I have cool looking NS12 with big heatsink
asw7576, after repeating so many times that they are not the same, you're still doubting?
Don't be lazy. Just download the PDF file for the part's list of the complete NSR12 and NS15 engine. See for yourself which part numbers are the same and which ones are different, to which I've already mentioned it above !
Old 01-09-2005, 10:21 PM   #678
asw7576's Avatar
..... don't get me wrong, man. I have search everything from www.novarossi.it and www.teamtrinity.com. Even yahoo search. The info file for ns15s5 parts listing are none. That why I asked everyone expertise and experience.
If everything else is failed, then I have no other option except to re-order the ns15s5 complete set piston, sleeve and conrod.
Old 01-10-2005, 12:04 AM   #679
InitialD's Avatar
Have you search enough? Can't be that difficult eh?
http://www.novarossi.it/eng/ns15s5.htm
Click or download the exploded view for the NS15S5 engine in PDF file format.
http://www.novarossi.it/eng/ns12.htm
Click or download the exploded view for the NSR12S5 engine in PDF file format.
All the part numbers are there. Compare the part numbers ! See which ones are the same and which ones are different.
Please re-read my replies to TRAJ above...
You would still need to get the NS15S5 piston sleeve set because they are completely different from the NSR12S5 engine. The conrod for both engines are the same though...
Old 01-10-2005, 01:01 AM   #680
TRAJ's Avatar
D is right
the internal diameter is different on the crankcases
TRAJ is offline   Reply With Quote
Old 01-10-2005, 02:46 AM   #681
asw7576's Avatar
Jezuz Christ !!! I think I must see eye doctor, I skipped the exploded view !!!
Thanks alot D !!!
Old 01-10-2005, 03:01 AM   #682
asw7576's Avatar
Ok, I got the full information, the difference is major ...... I must re-order specific parts for specific model. Aargh.... bye-bye my crazy dream of having .15 engine with .12 internals.
This hobby is expensive.
Old 01-10-2005, 10:19 AM   #683
InitialD's Avatar
Originally posted by TRAJ
D is right
Which internal diameter are you referring to? Internal diameter of the crankcase where the piston sleeve sits in or the internal diameter where the crankshaft / bearings slot in?
Old 01-10-2005, 09:13 PM   #684
TRAJ's Avatar
for the sleeve, so ive been told
Old 01-14-2005, 08:55 PM   #685
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Hopefully gonna pick up an NS12S3 from the LHS for my R40 and for my 8th scale I've been thinking about the BS21SB, or just get the 421B. Anyone have experience with either? RB is great, but under race conditions it's been Nova outlasts it.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 01-15-2005, 02:14 AM   #686
asw7576's Avatar
I tested my ns15s5 mod today, the result is . Engine sound is very loud and long, the top speed...... i don't know because the car already arrive at next sweeper. Some JP racers asked what kind of engine because they notice my car's engine did not peak at straight, but I didn't tell the mod yet
Old 01-15-2005, 09:45 AM   #687
asw7576's Avatar
Originally posted by daniz24
08659 COMPLETE SET PISTON/SLEEVE 5L (MICROCASTED)
I want two set please....
Old 01-30-2005, 12:18 AM   #688
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
RS4LOLA: I am also running the RR12L3....It has something to be said about it. I pulled it apart after 2+ gallons and replaced the Rod, I had stretched it and cracked the barilium bushing and it was running "SICK". I blew the 2 speed hub "actualy snapped the ring" from the back side of the gear. I have pictures to prove it and the parts too. This motor is crazy, tunes easy and out-runs most other motors. (I just need some more track time and learn to drive better) Even at the long back strait of Kissimmee, it pulls away (or catches) just about everything. ONE THING, CHANGE THE CONNECTING ROD!!!! It is now stronger than it was before,
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 01-30-2005, 09:02 AM   #689
Hey guys. I have an option to get a Novarossi 3POrt 28 engine for 150 dollars. I have the LST with the Mach 26 and wa swondering if anyone could HELP ME HERE!!!!Now I hear all over the Mach 26 is like the all round best liked engine? Now I wanted to know if the Novarossi 28 would be faster or stronger then the Mach 26. You know a NOTICABLE diffrence that i will see with it in there? I meanis it worth spedngin the monmey to egt the engine even at that great price? If it is not really gonna impress me as being alot or even noticabley better then the MAch I would rather stick with the Mach? Though a new Mach is almost the same price? So i should just get the Nova? I mena its got be alittle better and or at least equal? Let me know what you guys think? Also i was wondering what the TOUGHEST engine for big blocks is out reight now? Fastest toughest strongest? Below:
Sirio 27 Race or Pro with pullstart
RB 28
Nova, Rex, Top 28's 8 port or 3 but has to have pullstart
CEN 46
Collari 30
MugenLUVE is offline   Reply With Quote
Old 01-31-2005, 07:07 AM   #690
rcfoolz:
Thanx for the info. Yes the rr12l3 is grreat.!!! I have less than a gallon thru it and have not raced it yet. Waiting for spring time as I think this should be a parking lot terror. Maybe you could answer my earlier question of whether I am running the low speed too lean. I am running 30% nitro with no restrictor with an RD Logics tuned pipe (legal) with a extened OFNA muffler coypler for added torque. I have barely touched the high speed needle and only adjusted the low speed needle so I could get the engine to idle during breakin. As the engine go stronger during breakin, all I did was turn the idle down so the clutch was not engaged. The car can idle thru one tank easy IF you want to wait near 15 minutes!!! Once this engine is heated up, no flame outs and VERY easy to tune. Was VERY hard to break in though as I had to use a heat gun for at least 7 tanks!!!. After the 10 tank I can finally start it without the heat gun. Now I have not run this engine since november. Du you still think I should change the rod BEFORE i start racing this spring??
rs4lola is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
