Like Tree33Likes
Old 12-21-2004, 05:30 PM   #616
BundyMan's Avatar
What's a good starting point to tune the NSR 5 port engine? I tried using the original settings LSN (2.5turns) HSN (5turns) and get flamed out all the time. Should I lean the LSN?
BundyMan is offline   Reply With Quote
Old 12-22-2004, 12:41 AM   #617
BrainTeased's Avatar
when does it flame out? while idling, taking off, or at WOT ?
also try to replace your fuel lines with new tubing, clean out your air filter, clean youir tank out, and new plug try number 6
and check your compression.
is that is a good starting point from memory at 5 turns the high speed is abit rich but bottom speed is a little rich but not so much to bog you down to flame out.
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 12-22-2004, 05:42 PM   #618
BundyMan's Avatar
Idling is okie I suppose, only when during take-off especially if it idles for like 5 seconds or so.
Rgds
Old 12-23-2004, 04:06 AM   #619
this sounds like the bottom end is extremely rich but at 2.5 turns out that should be very close.
actually whats it doing during take off? bogging down or just leaping foward like a rocket?
also what plug you running?
Old 12-23-2004, 10:32 PM   #620
BundyMan's Avatar
I have actually leaned to 2 1/4 turns LSN. A little reluctant to lean it further.
Its blubbering before it takes off. Once the car is running then its not a problem but cant idle for more than 5 secs. It will flame out when I press the throttle again. Running plug no.6 tf.
Rgds
Old 12-24-2004, 12:05 AM   #621
i had the same problems as you with my RS12S5 now that i think about it. i kept leaning my bottom end etc.. then tried to lean top end etc... i could never get the perfect running setting. and in 1 month of every weekend tunning it i eventually snapped the con-rod....
have you tried giving it to the guys at the track to have a look at it? the guys at my track said it was a shimming problem with mine.
Old 12-27-2004, 08:47 AM   #622
Default Kyosho V one S II with Nova RR12 L5
Need some help, I bought a RR12 L5 for my V one S II.
I have the original Kyosho 2 speed.
The problem is the RR12 has different thread then the original GS15 engine.
Any one know what I need to get in order to mount the engine and fit the kyosho 2 speed to it?
fredgoh is offline   Reply With Quote
Old 12-27-2004, 11:30 AM   #623
Trader Rating: 15 (100%+)
Anyone know of any web sites that show the mods. that you can do to the .12 nitro engines?
THE DOCTOR is offline   Reply With Quote
Old 12-27-2004, 03:13 PM   #624
B4
B4's Avatar
Default Bearing Part numbers
HI,
Sorry if this has been asked. I need to replace the bearings in two of my motors. NSR and NS. I measured the crank and both would appear to use the same front bearing. However the rear bearing I assume would be different because the NSR is 0.5mm larger (11.5mm) where the NS is (11mm). I'm not sure if all the NS and NSR range came with these spec cranks.
I have looked on the Novarrossi site at the expanded views and noticed that the part numbers for the bearing are the same. This doesn't seem right to me and I was hoping that someone could tell me if these are the right part numbers.
Front 17006
Rear 16602
Thank You
B4 is offline   Reply With Quote
Old 12-27-2004, 03:19 PM   #625
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
B4....
both NS and NSR series come with the same bearings.......
11.5mm bearing.....
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 12-27-2004, 03:33 PM   #626
B4
B4's Avatar
Originally posted by SalvadoriRacing
B4....
11.5mm bearing.....
Thanks SalvadoriRacing,
I have a couple of motors and thought one was a NS, it turns out to be an RS I lost the box it came in.
Can I swap P/S/R between the RS and NS.
Old 12-27-2004, 03:39 PM   #627
yes you can.....
the sleeve of NS and NSR series uses to have the exhaust port a little bit higher than the RS series....but always work, when there is a difference between the original sleeve and the NS/NSR sleeve, the engine will run even better, because the higher exhaust port yields more top end.......this difference is very little (usually 0.1mm), in most cases there is no difference....
the conrod is the same for RS ans NS/NSR series......only MT12 and RR12 engines have different rods....
Salvadori Racing
Old 12-28-2004, 01:13 AM   #628
rcabj's Avatar
Default rr/nsr?
i have been told the RRL engine is for small to medium track cause u need the extra bottom end punch....
is this true..thanks
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 12-28-2004, 03:43 AM   #629
TRAJ's Avatar
Default Re: Kyosho V one S II with Nova RR12 L5
You will never get the RR12 to fit your V one SII
the engine has a SG crank made for Pro tourers
the V one SII needs a threaded crank
so the RR12 is a no go in the V one SII!
TRAJ is offline   Reply With Quote
Old 12-28-2004, 03:44 AM   #630
TRAJ's Avatar
Default Re: rr/nsr?
Yep thats true
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
ralphierace13
