Old 12-16-2004, 09:46 PM   #601
j240z's Avatar
Unhappy pullstart woes..
Does anyone know if the RB .28 pullstart is the same as the novarossi/Top .28 pullstart?
j240z is offline   Reply With Quote
Old 12-18-2004, 08:27 PM   #602
I'm having a very strange problem.I'm running an NSR12s5 powered G4.Everytime I pitted in ,about 5 to 10 seconds the engine would quit.Meaning once the fuel tank is open engine would quit shortly.After restarting it would run no problem till next refuel.It was costing me the race but I still managed 2nd place despite flaming out 5 times due to refueling. Some says to shorten the pressure tubing (which is about 5inch) but I'm not really convince.Please help.Thanks
Zizu is offline   Reply With Quote
Old 12-18-2004, 09:18 PM   #603
TRAJ's Avatar
do you keep reving even when your refueling???
TRAJ is offline   Reply With Quote
Old 12-18-2004, 11:23 PM   #604
Yup I did in short burst.
Old 12-19-2004, 12:29 AM   #605
TRAJ's Avatar
umm i think your idle needs to be raised abit
OR this is probably what it is, have you tried another glow plug to see if thats the problem?
Old 12-19-2004, 06:46 AM   #606
cdelong's Avatar
I have a M8 transmitter and just hit the bump up feature while I'm pitting. Raises the idle just like when starting it.
cdelong is offline   Reply With Quote
Old 12-19-2004, 04:44 PM   #607
Regional Moderator
daniz24's Avatar
Have you check your endplay or other clutch setting?
Sometimes the centax spring nut is loosened and that will cause the engine won't idle...
daniz24 is offline   Reply With Quote
Old 12-20-2004, 01:07 AM   #608
Plug is new and it's not idling problem.It's just that once the tank is opened then it would quit shortly.After restart then it'll be ok till the tank is opened again.I might check the clutch though but I doubt it's the cause.
Old 12-20-2004, 01:09 AM   #609
Originally posted by Zizu
I'm having a very strange problem.I'm running an NSR12s5 powered G4.Everytime I pitted in ,about 5 to 10 seconds LATER the engine would quit.Meaning once the fuel tank is open engine would quit shortly.After restarting it would run no problem till next refuel.It was costing me the race but I still managed 2nd place despite flaming out 5 times due to refueling. Some says to shorten the pressure tubing (which is about 5inch) but I'm not really convince.Please help.Thanks
Sori.This is what I should have wrote.
Old 12-20-2004, 10:02 AM   #610
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
your bottom end needle might be too lean, under presure you just barely have enough fuel to pass through, but once the lid is open you are loosing alot of pressure so not enough fuel going through!
Ah10 is offline   Reply With Quote
Old 12-20-2004, 04:45 PM   #611
Sounds logical to me.I'll try to retune the engine again.
Daniz.You drive the G4 don't you??Is this by any way indication of the supposed faulty fuel tank?Could this be the problem?
Thanks a lot guys
Old 12-20-2004, 05:26 PM   #612
Ah10's Avatar
Thanks a lot guys
Try pinching the fuel line when it is idle, if the idle rise up instantly then most likely your bottom end needle is too lean, it should be like a couple of seconds then start rising.
Old 12-20-2004, 07:13 PM   #613
Thanks a lot guys
From what I ever found on some G4 tank, there is some plastic flashing on the neeple.
Just take out the neeple, clean the tank and inspect throughly area near neeple. Thats could be the case.
If not helps, Ah10 explanation is mostly the case
GoldFinger is offline   Reply With Quote
Old 12-20-2004, 08:00 PM   #614
Thanks GoldFinger I'll do just that
Old 12-20-2004, 08:33 PM   #615
Regional Moderator
daniz24's Avatar
Maybe. I've also experienced this about 2 or 3 months ago, and I directly switch the engine and the problem is also gone. So I don't suspect the fuel tank that moment, but in your case maybe it's different. Please let us know after you fixed the problem.
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 11:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 06:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 11:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 06:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 07:28 PM
SEO by vBSEO 3.5.0
